    Just Nature !
    25 Posts 19 Posters 3.5k Views 19 Watching
    • brodieB Offline
      brodie
      Totally agree w/ what everyone has said, this looks really good. The grass and background/midground looks amazing. The foreground low-poly trees look...well, low-poly, but what do you expect? Very nice
      -Brodie
        Jackson
        Easily the best rendered grass I've seen in an animation- on the low camera sweeps it really looks like there's blades of grass sticking up! I tried the 2 plane method before, but it came out nothing like this, it just looked like a fragmented flat textured plane. Also the clipmap made renders slooooooow. 😞 Great work 👍
        Jackson
          Jackson
          Forgot to ask- if Fry recalculates face-me geometry before every frame, doesn't that make for very slow renders as it has to parse the scene before rendering?
          Jackson
            kwistenbiebel
            When hitting the render button (a green arrow icon), there will be a warming up period (= export phase) and you'll see the SU viewport shift through all the scene tabs and in between frames. For a longer animation (300 fps) this takes about 5 minutes in total. For each frame a .bin file is written in the process.
            Once that geometry phase is done, the render screen will pop open and starts rendering all the frames.
            The fact that Fry will take geometry changes,layer visibility etc. into account makes a lot possible: object animation, face me components and all attributes per scene will be shown.
            Currently there is a bug when trying to render animations on really big files as a temp folder will get 'full'. I hope that will be fixed soon.
            About the double surface grass: the blades of grass aren't really there. It's a fortunate side effect of compression 😄
            • Y Offline
              yuyayu
              😍 Wow wonderful trees and good tip. VFS now can not render animation camera facing object correctly.
                silver_shadow
                nice work biebel!!
                Listen, is it possible you can show us a tut how to build this realistic grass effect, maybe throw a texture or two in for us to experiment with, pretty please. 😎
                  JuanV.Soler
                  really good ¡
                  I like it very much
                  • marked001M Offline
                    marked001
                    the resurrection of this thread just reminded me of this thread... http://www.maxwellrender.com/forum/viewtopic.php?t=29892
                    http://www.revision21vis.com
                    instagram: revi21on
                      Jackson
                      Jason, that link requires registration so maybe not so useful for everyone. Thanks for posting though- that model is absolutely stunning, I wonder where he got his clipmapped textures from?
                      Jackson
                        marked001
                        ah, damn....you're right.. alright.. well i'll just post up the images.. from Stack! Studios.. apparently there are 12 clip mapped planes and 50 textures making up these images.. crazy!
                        http://updown.stack-studios.com/nextlimit/vegetation02.jpg
                        http://updown.stack-studios.com/nextlimit/vegetation03.jpg
                        instagram: revi21on
                        • 2 / 2
