    Hardware trouble with SU only ??
    4 Posts 2 Posters 463 Views 2 Watching
      bhnida
      hello guys
      i have "i supose hardware trouble"
      being most happy about my new system wich i specialy bought for big and much detailes SU models i face trouble with SU ONLY 😞
      all time i start a second instance of sketchup to see another file for example ore to copy a part out of it (i know i schould have and can make a component ore model)
      my system crashes ore better to say freezes.
      my system is 2 quad cpu 2,83Ghz grafik card is nvidia quadro fx 1700
      only with this system i have the trouble none trouble like this on my old slow PC 😞.
      waht can i doooo πŸŽ‰ pls help
      • TaffGochT Offline
        TaffGoch
        bernhard,
        I have a Quadro, as well, and it works great. I downloaded a new driver from nVidia (as opposed to Microsoft or DELL):
        http://www.nvidia.com/Download/Find.aspx?lang=en-us
        Windows Vista 32-bit drivers:
        Quadro 178.26 / Oct 15, 2008
        Quadro 169.96 / Jun 6, 2008
        Quadro 169.47 / Apr 3, 2008
        Quadro 169.39 / Feb 22, 2008
        ForceWare 162.65 / Nov 9, 2007
        ForceWare 162.67 / Dec 11, 2007
        Windows XP drivers:
        ForceWare 93.81 / Nov 28, 2006
        If you have Windows XP, nVidia offers a [url=http://www.nvidia.com/page/partner_certified_drivers.html:zbsup7u9]"Partner Certified Driver"[/url:zbsup7u9] for SketchUp. That's the one that fixed some minor issues I was having with SketchUp.
        If you have Vista, experiment with the available drivers, to see which provides the best performance. (Your description sounds like a common Vista problem, so I'm guessing that you have Vista.) If one of the above drivers doesn't fix your problem, you may benefit from this 'workaround' for Vista: [url=http://sketchup.google.com/support/bin/answer.py?hl=en&answer=69299:zbsup7u9]"Freezing upon launch" - SketchUp Help Center[/url:zbsup7u9]
        Taff
        %(#BF00BF)[DELL Precision M90 / 2 GB RAM
        nVidia Quadro FX 1500M / 256 MB
        nVidia driver: Forceware 162.65]
        "Information is not knowledge." -- Albert Einstein
          bhnida
          hey TaffGoch,
          thanks a lot for your fantastic 100% help.
          after installing new drifer all worked and i experienced a power exploasion in working with SU
          all is so smoot orbiting now even the biggest and complexest models πŸ˜„).
          thanks again if i can be of any help for you please select from here...
          i could help with things like ....
          http://www.medianet-home.de
          http://www.voicepoint.de
          whatever you need πŸ˜‰
          best regards bernhard
          • TaffGochT Offline
            TaffGoch
            bernhard,
            So, which driver worked for you?
            (You are on Vista, right?)
            This info could benefit others...
            Taff
