MIRROR
Hi...
Is there any way to make a mirror surfice???
I need a real mirror and not a thing that looks a like
You have Podium for example : select a face and increase the Cursor "Reflect" so you will have a perfect mirror
In a word, no. You cant have a shiny surface natively in SU. As pilou said you need to get a rendering engine like podium.
Here is my attempt at reflections.
1/ Drew a rectangle
2/ Painted with Translucent
3/ Copied Bryce, - Pasted in Place
4/ Chose Flip along Blue axis
5/ Moved to the underside of Bryce.
6/ Drew the box, and imported the Mail box and did the same procedure as above
7/ Went to the planes entity info and worked my way to the transparency and tweaked..Similar procedure for mirrors
