    Creating water spray...
    17 Posts 9 Posters 4.2k Views 9 Watching
    • utilerU Offline
      utiler
      thanks solo,
      No, I'm looking at a sketchy marker or watercolor [ 🤣 ] illustration maybe.....
      Just Curious...
        remus
        perhaps some transparent face-me PNGs? I doubt anyones going to miss the shadows from them.
        • utilerU Offline
          utiler
          thanks Remus, do you think maybe using that ruby is the way to go then 'reload' with a component containing transparent faces, no edges, etc...
          Just Curious...
          • Alan FraserA Offline
            Alan Fraser
            Pngs are definitely the way to go. You can create a wide range of effects...both painted onto shapes and as freestanding Face Me images.
            http://www.formfonts.com/viewModel.php?view=1&id=5105&config=1
            http://www.formfonts.com/viewModel.php?view=1&id=4926&config=1
            The best way of doing it is to paint in pale blue and white in an image editor. Do this on a transparent layer that is on top of a dark grey or black background...in order to see all the subtlety. Then delete the background and save as a png.
            3D Figures
            • utilerU Offline
              utiler
              Thanks Alan, I'm not a frequent 'image editor' unfortunately.... will have to learn i guess.
              So create an image that resembles water in say PS or GIMP [which i have] as you say and paint a shape created in your model that depicts the the spray of water....?
              Just Curious...
                Hi Andrew - I'd go even simpler. As Alan sid, you can create the image of just the spra without any background showing around it.
                No apply this semi transparent image onto a single Face in SU, hide its edges and turn it into a face-me component.
                  Alan Fraser
                  Gimp should work fine. I produced this image by simply placing a few random white dots on a clear layer. I then copy/pasted them to fill the image area and applied a speed blur.
                  The instructions in the skp are pretty obvious. Good Luck Andrew
                  Edit: You can just do a Face Me as Gaieus suggest, but my experience is that this only works well if you have a spray going vertically upward. If it's angled, then it tends to twist and turn in all kinds of unwanted ways. That's why I have gone full 3D...it's only 24 faces.
                  water spray.skp
                  3D Figures
                    twharvey
                    Andrew,
                    Here's another example of fountains form a Google site: http://www.google.com/intl/en/sketchup/3dwh/acceptance_criteria.html
                    Just scroll down to the foutains Picture.
                    Tom
                    Tom
                      sorgesu
                      Yep, works. Sorry Alan, please forgive, I used your shower with my "fountain" stretched and squashed and rotated. The pivot point is at the original base of the fountain which is now positioned on an agle against the opening of the shower head. The whole thing rotates correctly as I orbit around the model pivoting around it's origin at the shower head on the same angle as it's z axis
                      Susan Sorger
                      Former Seller Hand Rendered Entourage
                      Former Canadian Authorized Training Centre, SketchUp
                        sorgesu
                        watercolour fountain available as an SKP face-me or as a High resolutin PNG.
                        http://www.entouragearts.com/shopexd.asp?id=1309
                        I grabbed an old incomplete SketchUp Model with a fountain in it and placed in the water fountain so you can see the the SKP one in action.
                        The spray will "tiwst and turn" about it's "origin" so if you want to cut this up and angle, just make sure you keep the origin centred in the middle of it's base as it is in this one. when you angle the fountain bit the origin will stay as is and it will angle with the rotation. It will pivot around that origin in that angle as needed.
                        Susan Sorger
                        • utilerU Offline
                          utiler
                          Thanks to you all for your efforts and great suggestions... I want to get into it but have a mountain of work to get through and besides; haven't even got the job yet!!! Will post when I have had a play...
                          Thanks again, you guys are GOLD!! 👍
                          Just Curious...
                          • utilerU Offline
                            utiler
                            So I got the job!!! Will start on it today and have to submit by Tuesday next week.... better get cracking!!!
                            Will post along the way for comments.
                            Cheers again.
                            Just Curious...
                              sorgesu
                              Congratulations!!
                              Susan Sorger
                              • tinanneT Offline
                                tinanne
                                Awesome Andrew! Congratulations.
                                Executive Director : American Society of Architectural Illustrators
                                AIP 30 Competition opens soon. ASAI.org
                                Architectural Rendering
                                  mrjumpmanv2
                                  sorry this post has nothing to do with this, just wanted the 10,000th post =p
                                  %(#000040)["Anyone who has never made a mistake has never tried anything new."
                                  Albert Einstein]
