    Connect two open shapes together ?
    13 Posts 5 Posters 1.7k Views 5 Watching
      remus
      That only works in a few situations though, if you rotate your example through 90 degrees (for example) it will not work, whereas the methods i suggested should work in most situations.
        muralt
        Thank you all for the answers. The problem I have is to connect this two arcs to make a closed
        3D outlined (wire) and then use the script "Soap Skin & Bubble". Does someone know how can I make it to make a closed 3D outline ?
        Thank you all of you !
        • soloS
          muralt,
          I am sorry but I do not understand exactly what you want to achieve, could you try explain a little more maybe show an example of what you need and upload the .skp for us to play with once you have explained.
            muralt
            Solo,
            The soap skin & bubble script allow me to make shape like you can see here :
            http://www.tensile-structures.de/help.html
            But first how can I make a closed 3D from two arcs and then generate the script?
            Thank you for your kindness.
            • soloS
              I now understand, I am sorry however but I cannot help as no matter how many times I tried to remove my old version of 'soap bubble' and replace it with the new one it still tells me my time limit is up, so I do not use that tool anymore.
                remus
                Whats stopping you form just drawing a line in?
                • Jean LemireJ
                  Jean Lemire
                  Hi Muralt, hi folks.
                  You must specify the path that is to be used when going fom one shape to the other.
                  Is it linear or curved. If curved, what type of curve ?
                  Just ideas.
                  Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
                  • soloS
                    However, I use other tools like sub-divide to achive similar results.
                    http://img403.imageshack.us/img403/7512/soapbubcy0.jpg
                    • GaieusG
                      ...or two, connecting, smaller arcs if you want it a bit smoother?
                        muralt
                        Hello Solo,hello all,
                        i'm new with SU, could you explain me more about the sub-divide tool in order to achieve the same result you send me.
                        Thank you.
