    Elev45shadows.rb help
    24 Posts 4 Posters 3.8k Views 4 Watching
      rv1974
      The same here. The cure is to change location degree a little bit (+-1).But If you'd fix this right state by creating a page it wouldn't remember right shadow position
      Stop using this .rb is better solution.
      Even more: I guess the shadow stuff is the most stinky part of SU: the pages don't remember shadow position,after export-import pages (exim.rb) your skp file get into twilight zone- no shadows at all,
      codec tragedy etc 🀒
      • TIGT Online
        This script is nearly three years old and no one has reported this problem before...
        Are you using it as set out in the instructions ? Remember to set up specific pages (scenes) for these 45 degree shadowed elevations since the 'real' location/shadows are never going to give the desired angle etc at any time/day... When you've applied the 45 degree shadows to a page update that page tab so it remembers the settings for that elevation...
        ... extract from start of script...
        Usage : Set up your elevation-view page(s). Tip - Select an
        elevation face and right-click and pick Align View to
        get a non-orthogonal [non-F/B/L/R] elevation.
        Then select this tool from the menu and it will
        automatically work out camera view direction and add
        shadows as if the sun is from the top-left of the view
        at 45 degrees in elevation or in plan...
        Note aligning views to 3D sloping faces will have
        unexpected affects.
        It will realign North in each altered view so IF North
        is important in other shadow studies ensure that pages
        are kept separate.
        Shadow setting changes are NOT Undo-able...
        To toggle shadows to 'top-right' for that session open
        the Ruby Console, and type or copy-paste the following
        and press enter = $e45s=0
        to turn back it's = $e45s=1 or just restart SketchUp.
          rv1974
          Hi TIG!
          This is a typical situation after your script. Check it please.45.skp
            rv1974
            In this case restoring scene1 repairs everything but very often only tweaking location degree helps. I thought it's a video card issue but it jumps out on different PCs. πŸ˜•
            • TIGT Online
              What you uploaded hasn't has 45shadows applied to it- see original location etc. If I apply 45shadows it works fine ? Your Country and Location should change to "Elevation 45 shadows" !
              Please explain the steps you take and what goes wrong when...
                rv1974
                1/ Align view for some specific face.
                2/ Create a scene.
                3/ Apply script- get black hole sun.
                4/ Update scene- darkness stays on (see attachment BEFORE clicking "scene 4")
                5/ Closing- reopening- restoring specific scene- everything is OK (click scene 4 tab)
                45-3.skp
                • TIGT Online
                  Even your Scene4 tab is NOT fully 45 degrees ? I can't get this error to reproduce at all. At my end everything works as expected, when I run the script the scenes's settings are changed correctly and the updating saves it...
                  What version and OS are you on ?
                  • brodieB Offline
                    brodie
                    My problem is, indeed, identical to RV's problem. I'm on Windows XP w/ SU6. What seems to happen is that the degree of the sun angle will change but from what you've said the location should also change, but it does not. It simply stays at Boulder, CO. I wonder if the script looks for something that it can't find on my computer (like the location of 45 Degree Shadow)? I don't know ruby so I'm just guessing. The script would come in really helpful though if it get's fixed. Let me know if there's any more info I can provide that would help you diagnose the problem.
                    Thanks,
                    -Brodie
                    • TIGT Online
                      The script forces a new place / country and north-angle, + sun=angle so that the shadows work at 45 degrees on that elevation. As I said I can't get it to reproduce here and It's fine on simialr set ups to yours... ???
                      • brodieB Offline
                        brodie
                        hrm...guess I'll have to settle w/ my ol' 48 degree manual shadows 😞
                        The other weird thing I've noticed is what your ruby does to the time settings in the shadow settings dialog box. Don't know if this is intentional or not. If you open the first skp file RV posted you'll see that it sets the time to go from 11:10am to 11:01pm. I'm not sure if it's always this range but it is always changed to a very odd range and as I recall this affects all other shadow settings. I'd have to go and verify but I think if you've already got a scene set up, say scene 1. and then you go into scene 2 and apply the ruby and go back to scene 1 the slider is in the same position but since the range changed what was, say 1pm, is now, say, 10pm.
                        Let me know if any of that make sense or if you need me to go and verify all that stuff. Don't know if it'll help you.
                        -Brodie
                        • TIGT Online
                          The script has to (re)set the time (and where north is) to get the sun at the right place in the sky to cast the shadow at 45 degrees on the chosen elevation. If you have several pages (scenes) set up you should ensure that they are saved with the particualr location and date+time etc you desire. Make new page(s) for the 45 degree shadows and when it's done update that too...
                          You should be able to have several pages each with different times/dates etc...
                          • brodieB Offline
                            brodie
                            I took a quick crack at it. This file has 3 scenes. I created the first 2 w/ shadows on at different times of the day, then created the 3rd one using the ruby (which turned everything dark as it has been). Going back to my other scenes did indeed change the time range back to normal however everything was still dark, weird.
                            -Brodie
                            shadow test.skp
                            • brodieB Offline
                              brodie
                              TIG, could you post a skp file w/ a saved scene using your ruby so I can open it and see what happens?
                              -Brodie
                              • TIGT Online
                                Here's an example...
                                A normal scene plus a north and west elevation with 45 shadows. Update each tab as the scene is made and each scene has a different north, date, time, location etc to get the shadows as needed...
                                45test.skp
                                • brodieB Offline
                                  brodie
                                  Very interesting. Here's what I'm finding. Using your plugin does indeed change the location in terms of latitude and longitude. What it doesn't change is the name (still Boulder instead of Elevations 45 Shadows or whatever) or (here's the important part) the time zone. Time zone stays at -7 (Boulder's time zone) rather than switching to +0 (the time zone in the skp file you posted).
                                  Starting a new drawing, using your script and then manually changing the time zone produced results identical to the results of your sketchup file.
                                  HOWEVER, when I open your SU file the shadows aren't truely 45 degrees. Well, I take that back. They are 45 degrees, however the shadows aren't as long as I'd expect them. For example, if a block is protruding out 1 foot you'd expect the shadow to travel 45 degrees and to stop 1' down and 1' to the right. W/ your script it travels 45 degrees but not quite the full 1' down and 1' over. Check out the example below. On my screen the shadow stops just before the purple face. I'd expect it to travel to the far end of the purple face.
                                  I think we're getting close here. On your screen does the shadow cover up the purple face in my example because on mine it doesn't.
                                  -Brodie
                                  45test 1.skp
                                  • brodieB Offline
                                    brodie
                                    an image to reiterate what I'm saying
                                    • TIGT Online
                                      It always changes the location name for me...
                                      Point taken about the 45 degree accuracy. I've fixed it to within a smidge of a mm... Needed minor adjustments to time of day and long/lat to get it 'as near as damn is to swearing'. The 'Boulder' Time Zone bit was from a typo that's corrected...
                                      See updated script... http://www.sketchucation.com/forums/scf/viewtopic.php?p=98081#p98081
                                      • brodieB Offline
                                        brodie
                                        Bloody wonderful. Agreed, that is much closer. That did, indeed fix the location issue (doesn't still say Boulder, CO any more). I'm still having to manually change the time zone from -7 to +0 but I can certainly live w/ that! Thanks a ton, glad we finally figured this out.
                                        Only thing I'd suggest is adding a caveat in the text of your script and maybe in that other post as well to folks, that if the screen goes dark after running the script to go to Window -> Model Info -> Location -> Custom Location button and change time zone to UTC-0
                                        Thanks again!
                                        -Brodie
                                        • TIGT Online
                                          http://www.sketchucation.com/forums/scf/viewtopic.php?p=98194#p98194
                                          Here's v1.4 - it should fix the T Z Offset error ???
                                          • brodieB Offline
                                            brodie
                                            Wonderful! It works like a charm now. Thanks so much for fixing it!
                                            -Brodie
