    Centering with the Rectangle tool
    6 Posts 5 Posters 969 Views 5 Watching
      darkhelmet
      I created a post 4",4" and then extruded it up about 6'. I want to add a cap to it but unlike the Circle and Polygon tools, the Rectangle tool does not have a 'center' guide so I use a Ruby plugin (Set Center Point) to make a center guide on the top of the post.
      My problem starts when I want to extend the rectangle cap from the center using a specified size. I cannot seem to constrain the size from the center - when I type in dimensions the rectangle is sized from one side. How do I get it to constrain from the center so the size is uniform from the center of the post with a size I input?
      • H Offline
        Hazza
        The Offset tool?
        See all of my SketchUp models here.
        • H Offline
          Hazza
          @taffgoch said:
          Draw a diagnonal across the square, then split it in half (you can use the midpoint inference.) There's your centerpoint.
          They are not having a problem finding the centre, they can do that with the CenterPoint plugin.
          I have attached a tut on how to create a 1" cap on the top of the leg.
          leg-cap-tut.skp
          • TaffGochT Offline
            TaffGoch
            darkhelmet,
            [ Hazza has corrected my misreading of your query. Please ignore. ]
            Taff
            "Information is not knowledge." -- Albert Einstein
              OK, I think I'm starting to understand the question.
              So if you want another "concentric" rectangle, either use the offset tool as Hazza suggested or you can draw a four sided polygon (they are always drawn from the centre).
              Choose the polygon tool, type 4s (i.e. 4 segments/sides) and hit enter to start with the shape
              • Jean LemireJ Offline
                Jean Lemire
                Hi folks.
                Just in case you did not saw the tutorial where this was shown, you can use a double inference from two adjacent sides of a rectangle (or square) to get its center. The procedure is as follow:
                1 - Find the inference from the midpoint of one side. Wait for the pop-up to appears.
                2 - Immediately find the inference from one of the midpoint of one of the adjacent sides. Wait for the pop-up.
                3 - Move roughly where the center should be. You shall see inference lines to both choosen midpoints. This is the center you want.
                Just ideas.
