    The City Of Ankh-Morpork W.I.P.
    68 Posts 18 Posters 16.5k Views 18 Watching
    • G
      geh4evr
      Because I'm so good I've uploaded 2 very quick test renders of the progress so far. Keep in mind that all the buildings are super low detail to start with, and as it goes, I'll add more details.
      And in case you ask, It's said that the river is based on the Thames.
      • GaieusG
        Hi Jacob,
        This is going to be a fun project I believe (although I already pity your computer).
        If I were you,I'd keep this "low detail" variation as a master model, turn each building/block into components, export the components,work on the details in smaller,individual files and at the end re-import them. Maybe onto a separate layer for the detailed ones while keeping the simpler ones on another layer.
        Then using scenes you could easily switch between the simple, mass modeling variation and the detailed one.
          Aernoud
          Good work!! I had once tryed to make the city of Osgiliath, ruined harbor city from the Lord of the Rings. That looks a bit like the map of Ankh-Morpork! (I didnt finsicshed it cause my hard disk chrashed 😠 ...) Succes, cause it is so much work, all the buildings!
          Currently SU project:
          • Metroid Prime large leviathan (own design)
          • Metroid prime plasma turret (own design)
          • Metroid prime Armour clubber (own design)
          • The Minas Tirith project
          • Mobile phone (own design)
          • T
            tomislavm
            Hm, I have made old town of Osijek,Tvrdja,and I was doing this for 2 years and every time i see some mistakes, next project was today town Osijek, it is an crazy job,good luck!
            • G
              geh4evr
              That's exactly what I had in mind. And don't worry to much about my Laptop, It's got 2x 3.6 GHz Processors, They shouldn't be too tired at the end of it. 😉
              Tomislavm, In total, how many hours would you say You've been working on that City?
              • T
                tomislavm
                About 60 hours.
                • H
                  Huggkruka
                  Haha, I actually have that on my wall. Must have been really hard work translating it. Clay renders looking great so far, very organic and nice.
                  • G
                    geh4evr
                    Thanks very much! Might I ask what you mean by Translating it?
                    • H
                      Huggkruka
                      The names in the link you provided looks slavic or balcan, while the original is in English.
                      • GaieusG
                        @ Gaius :Question about component
                        A file "big city" is saved with a component named "little house"
                        Open a new file, and modify the component "little house", and saved the component "little house" as component
                        When I reload the file "big city", the component "little house" is not actualized inside!
                        Is that normal?
                        Pilou, the way it works is to right click on the component either in the browser or in the model and from there choose "reload". Then an "Open" window opens where you can navigate to the modified file.
                        Be careful to always keep the original world origin however because that's the insertion point.
                        • G
                          geh4evr
                          Ah Yes... You see the reason they're not in English is that it's the only map of that type(and resolution) I could find on the web. So in the case of no map, or slavic/balcan map, I'll take the slavic/balcan map.
                          As for progress, None. I might work on it later tonight.
                          • GaieusG
                            It's Czech I believe.
                            • P
                              pichuneke
                              Fantastic Work! I will subscribe to this thread (I am reading now a book of Terry Prattchet, the spanish name is "Rechicero"). It's a pity, I don't have enough level of english to read it in english, I know that I lose some of the jokes 😆
                              Forgive my spanglish...
                                @ Gaieus :Question about component
                                Is that normal?
                                • GaieusG
                                  Sure, that as well. Mine was the "native" solution.
                                    @Gaieus
                                    Seems the Xreftools by Tig makes that I want 😉
                                      angusog
                                      G'Day Jacob
                                      I have always wanted to try and do this since i found SU, seeing your model and now i have a wee bit more experience with SU i,m gonna give it a go too. don't know about low poly tho as each part is individualand very few of the buildings are the same gonna be huge.....as you will see it's my third attempt.... using normal SU tools with the sandbox being the main one used...
                                      I have ordered the Terry Pratchet books "streets of ankh morpork" and "Mapp of Ankh Morpork", any interesting photos or drawings i can get from them i am more than willing to share with you if you need further references to the city
                                      have attached a jpeg of my start on it, Model is 2,346' on a side
                                      6115.112KB
                                      edges 31649
                                      faces 11832
                                      city of ankh Morpork
                                      • G
                                        geh4evr
                                        That's looking pretty good so far Robert! It would be great if you could scan some images from those books, I've PM'd my email to you.
                                        Might I ask why there are so many lines on the East side of the city wall?
                                        And Sorry I haven't been able to get any more pics of the project, I've been doing a lot of traveling, and haven't set up my SketchUp PC yet.
                                          angusog
                                          those are the lines from the drape tool in the sandbox haven't had time to clean them up yet
                                          because i have set the city up on terrain from the sandbox (push/pull tool won't extrude on curved surface), i used the stamp tool from the sandbox tools to project from the map down onto the terrain, to get the streets i used the drape tool, then i will build the buildings and stuff on the map and position them on the terrain.edges are heavy because i used the freehand tool to copy from the map, not sure if using straight lines and half circles will reduce it much, I do intend to clean it up as i go along (if this is possible and won't complicate model too much)might require remodel we'll see as I add stuff to it
                                          just got email from book shop "streets of ankh morpork" on its way to me, map is out of stock till 14 nov
                                          • F
                                            flyashy
                                            You know what, this is a very noble project!
                                            I've always loved all the books in the discworld series and always always wanted to build it as a model.
                                            And wasn't at all happy with what they did in the films.
                                            But yes it is a tall order for one person. might I suggest that you invite interested people to participate in this project and individuals can develop sectors. I, for one would be definitely interested in doing a small part of the city. That way you can actually get the different characterizations that are supposed to exist in Ankh-Morpork and it'd also be a lot faster.
                                            What do you say?
                                            ta,
                                            ashy
                                            • 1 / 4
