    Newbie Question: Placing objects on top one another
    19 Posts 6 Posters 25.5k Views 6 Watching
      rocker9455
      Hi everyone,
      As you may guess i fairly new to sketchup (you can probably tell from my drawing) i am having trouble drawing a lamp (for a school project) i need ideas on how to mount the shade in sketchup, i want to use dowels so that means drawing cylinders, which i can do!
      here is a screenshot:
      http://img340.imageshack.us/img340/7100/baselj8.jpg
      (or http://img523.imageshack.us/img523/7580/basefw5.jpg) if it doesnt display properly
      how can i place the cylinders and then place the lamp shade ontop of them, i want to leave a small gap in between the lampshade and base.
      Thanks,
      Will Price
      • ToboboT
        Tobobo
        I'm not totally sure what you want to do, can you post a sketch?
        Toby
        Philippians 4:13
          ridix
          One way is to make the cylinder away from the lamp first, than move it into place with Move Tool.
            rocker9455
            heres what i want to do:
            http://img523.imageshack.us/img523/7926/base123yh7.jpg
              remus
              The way id go about it is to offset the outer edge of the base to act as a guide. Id then draw a circle on one corner of the offset and pull it in to a cylinder. from there you could copy the cylinder across to each corner, using the offset as a reference. See the tut for more detail.
              lampshade tut.skp
                remus
                If you first select all of the top outside edge of the base then go tools->offset. You can then just offset the edge inwards from there.
                  rocker9455
                  thanks that is really helpful πŸ˜„, i was just wondering how do i go about setting an offset? πŸ˜• hehe
                  Will
                  Edit: this is how far I've got so far, ive done the offset and cylinders, its just placing the top on now!:
                  Base.skp
                    rocker9455
                    Thanks, ive got the offest sorted now πŸ˜„ just mounting the Shade πŸ˜• how do i do that?
                    • P
                      Paris
                      @rocker9455 said:
                      Hi everyone,
                      Thanks,
                      Will Price
                      Assuming the bottom of the shade and the top of the base are the same size.
                      Set your view to Top and draw a square the size of your dowel radius in each corner.
                      Draw an X to find the center of the square and use the circle tool to draw a circle in the square.
                      Use the Select tool (arrow) to highlight the area outside the circle and delete them. You should now have a circle inside each corner.
                      Use the orbit tool to turn the shade upside down so you can see the circles and then use the push/pull tool to pull the circles into dowels. Pull until they extend lower than the shade. You should now have a shade with four dowel legs. Highlight the shade and dowels and create a group.
                      Use the move tool to place the shade on the base. You can then highlight it all and make it a component.
                      • H
                        Hazza
                        ... or install the free CentrePoint plugin from Smustard.
                        See all of my SketchUp models here.
                          rocker9455
                          Thanks Hazza, Remus and paris you have all been exceptionally helpful πŸ˜„
                          here is my finished result (http://www.filefactory.com/file/5d8fbe/n/Final_Design_skp).
                          Please comment on it to what you think. Keep in mind I'm only 14 and that
                          was the first thing i have ever done in SU! I hope i can become involved
                          in this forum
                          Hosted on 3D warehouse (if you prefer it to file factory)
                          http://sketchup.google.com/3dwarehouse/details?mid=89fe9b63f07cde0fdd381eae8554f9d4&prevstart=0
                          • P
                            Paris
                            in this forum
                            Looks great. Now all you need to do is download the Podium free version and add some light.
                            Website Unavailable
                            (www.suplugins.com)
                              rocker9455
                              thanks πŸ˜„ i appreciate the support i will have a look at podium now
                                remus
                                I wouldnt worry about it for the moment, but your model is huge! i made a similar model quickly, just to check, and it was about 30 Kb compared to the 5.4 Mb of yours. Not really sure whats making yours so big, as ive purged it a few times and had a quick look for strange stuff but i cant find anything obvious. Anyone got any ideas what could be causing this? im rather intrigued now.
                                • H
                                  Hazza
                                  Pretty good for a first model, although I can't figure out why it is 5 meg in size for such a simple model.
                                  • H
                                    Hazza
                                    Remus bet me to it after I had an idea and went back to the model but STILL didn't find anything.
                                      rocker9455
                                      well the texture for the base was a picture, was about 2mb (high quality scans of wood) but the shade is only a little picture (just created a 40x40 pixel drawing in gimp and coloured it in half blue and yellow) and fiddled about with the settings to make it look good, hope this helps hehe
                                        remus
                                        That would probably do it πŸ˜›
                                          rocker9455
                                          hang on a sec, i just checked it again and it was a 5mb picture πŸ˜• hehe
                                          and again thank you all
