    [POLL]: If SU 7 will not have multicore/high poly support
    53 Posts 21 Posters 11.6k Views 21 Watching
    • H
      Hazza
      I urge each and everyone one complaining about this issue to look beyond the default settings for SketchUp
      Me me me!!! I want to do that but aren't experienced enough in SU to know what will help and what will kill it.
      Is there a list of all these tweaks? I always turn of profiles, but I dont even know how to make that the default 😞
      See all of my SketchUp models here.
      • philemP
        philem
        All the e.g. scripts, renders that Sketchup can work with makes it at great tool, and when you see work like e.g. "Silver Shadow" it makes you realise that modeling problems comes from bad skills and not from Sketchups capabilities.
        Truer words never spoken.
        I'm really fed up reading these complain posts that SU7 needs this and that it needs that or people will skip to another program.
        If that were the case, then why has the overall userbase of SketchUp exploded over the past two years ever since Google released a free version?
        Back to Ark's comments.
        I think most people don't really utilize SketchUp's interface to speed up their framerates. For examples, is anyone:
        • ...using the 'Hide rest of model' function found in the 'Components' section of the 'Model Info' panel?
          That requires a keyboard shortcut to operate in less than a second.
        • ...lowering their 'Transparency quality' [found in the 'Face Settings' section of the 'Edit' tab of the 'Styles' panel].
        • ...turning off 'Profile Edges' [found in the 'Edge Settings' section of the 'Edit' tab of the 'Styles' panel].
          And this list can go on for about 30 other tweaks, including but not limited to hardware settings which you can change in your display driver software that came with your video card, along with several tweak utilities by 3rd parties. And yes they DO help.
        This is not to brag, but I have a GeForce video chip based on the 7000 series which is considered old these days, and I can orbit models of up to 50000 SketchUp Faces with ease. Especially when changing the settings I mention above. And that does not mean automatically having to turn off Anti-Aliasing.
        Besides the SketchUp interface being underused there are a lot of external factors which determine SketchUp's speed. CPU is a big factor yes. But memory (RAM) and the type used does also, and it certainly makes a difference whether you are using slower or faster RAM.
        • Are you running any other applications besides SketchUp?
        • Does your video card contain the latest driver for your operating system?
        • Do you start using SketchUp when first logging on to your operating system, or after having ran several programs first? Especially some versions of Windows are known for not restoring free memory and clogging up your available resources.
        • Are you running SketchUp in a Windows environment on the Mac?
          SketchUp is not - and never has been - meant for high poly modeling. It was meant for sketching designs and bringing those into 3D. Not the over-the-top stuff that some people have been doing lately, really pushing SketchUp beyond its limits. That's all good and well and it certainly does arise the question if SketchUp has not outgrown the napkin modeler it was intended to be.
        Regardless of all this, what most people seem to have missed, is that SketchUp has DOUBLED its framerate speed when orbiting with each new version since v4.
        In v6 a lot of tweaks were introduced, among which is a very useful LoD (Level of Detail) feature which renders distant objects farther away from the camera as wireframe cubes.
        Other tweaks were made which hide certain Edges from view if the framerate drops below a certain level.
        What bothers me most, is that complaining about leaving SketchUp for something else. You all KNOW why you are using SketchUp and you all KNOW the feeling it gave you when you first touched it.
        As a SketchUp evangelist I know like all of you that no one company has even come close mimicing SketchUp's ability. They all try and fail. Instead, they copycat everything SketchUp does. AutoCad is an example of that with their Press/Pull tool.
        I don't want to go on forever with this post, but I urge each and everyone one complaining about this issue to look beyond the default settings for SketchUp and first see what YOU can do to improve its performance. Instead of relying on big G to fix your problems.
        I am still a bit of a newbie with Sketchup, basically doing basic stuff, I have done a plan layout for work of a new Water Tank sales yard, stuff like that, as I said pretty basic.
        But I have never seen or read of any tutorials of all these tweaks you mention.
        I have just looked at the video for 4 rubies and found the video very informative and helpful.... Is it possible to get a tutorial especially a video tut on how to perform these tweaks and their main benefits. . its much easier to appreciate the knowledge past on with visual help?
        Just do it, it might be fun.
        • K
          kwistenbiebel
          Me too. I use all the tricks Coen mentioned and SU still is mighty slow on high poly scenes.
          Just try importing 1 Xfrog tree.
          For low poly modleing SU remains ok.
          For high poly simply NOT.
          And Coen, you are right saying the new rubies expand the SU experience.
          A lot of those, however, ask for high poly support to be run smoothly , e.g subdivide 'nd smooth, Free from deformation etc...
            remus
            I'm really fed up reading these complain posts that SU7 needs this and that it needs that or people will skip to another program.If that were the case, then why has the overall userbase of SketchUp exploded over the past two years ever since Google released a free version?
            Its only the serious users who say this, and thats because they encounter SUs limitations on a regular basis and get rather frustrated by it. The thousands of new people who are using SU (usually as their first 3d modelling program) are hardly going tocomplain about the lack of proper UV mapping.
            Even if you do this SU can still only handle a very limited number of polys compared to pretty much every other modeller our there.
            Id have to say that SU most certainly has outgrown its napkin based beginnings. As you said, just look at what people are doing at the moment (looking at you again silver 😄 ) to see that SU is certainly capable of doing these really complex things, and that for the most part it is the poly limit that will hold people back and slow them down when trying to be adventurous.
            Lets hope that trend continues for 7.
            Yes the modelling aspect of SU is very good, but it does have very restrictive technical limitations. The fact remains that if people cant do the things they want (large terrain models spring to mind) then they will use another program.
            • StinkieS
              Stinkie
              That's not the feeling I got at Basecamp this year. People will do anything to stay with their beloved SketchUp.
              Hmmm, yes. There's some truth in that. Then again, you wouldn't find too many satanists at a synod, would you? 😄
              • GaieusG
                Hm.I made this model using an old machine with a 2.7 GHz CPU,a 256 Mb Ati Radeon x550 video card and 512 Mb memory. More than 1.2 million edges and 300.000 faces ❗ and I can navigate, orbit and what not in it with a laptop with 3.8 GHz CPU, a 256 Mb Nvidia 6800 video card and 2 Gb memory with no problem.
                Certainly I used a lot of "tricks" (like hidden layers and such) while modeling but by adding scenes in my workflow it wasn't a pain really.
                • BurkhardB
                  Burkhard
                  A lot of tricks is not really 3D for everyone 😉
                  http://www.ia-plus.de
                  • GaieusG
                    Well, each program has its learning curve and once somebody gets to the point that he/she wants to assemble such big models with lots of edges/faces, should already be aware these basic "tricks".
                    To model my house by making a simple box then texturing it with photos and uploading it to GE does not really need high poly support.
                    Nevertheless I admit that it would be nice and easier if SU could support higher poly count so don't think everybody that I am against it! 😄
                    • BurkhardB
                      Burkhard
                      Beware of it. 😮
                      To make some sense of Google explanations I sometimes would like to see more correlation with the userbase 👊
                      btw. 3D for everyone doesn't contain only simple textured squares for GE. my2cent
                      • GaieusG
                        I think there is - however the current Google software development policy (more exactly the non-disclosure of details) does not let them leak info about the directions of things.
                        Also they seem to have been busy lately 😒
                          rv1974
                          @Kwist: Read between the lines. If 2 the closest to dev camp guys ~1-3(?) month before v7 say "basically everything is ok- just turn off profiles,SU is meant to be lo-poly modeller"- this is a bad indication. Passover to cinema if hi-poly support is the key stone. What smily to drop here? 😒
                          P.S. I'd be glad to be wrong though- SU speed outweigh (meanwhile) all it's issues
                          • N
                            numerobis
                            ...yes, this seems to be the point! ...unfortunately 😒
                            i was afraid that this progress would happen as google bought it.
                            hopefully, there will be alternatives to sketchup in the near future - like bonzai...
                            btw: 50000 skp faces - maybe 500000 polys is NOTHING when you get into archviz
                            kwistenbiebel has said it: load only ONE bigger tree (maybe 200 - 300k) into sketchup and it's nearly dead. only importing this tree will take minutes! and then compare this with importing the same tree in max... 😞
                            ...and i've turned off everything i can in the settings
                            • K
                              kwistenbiebel
                              I know....There is no indication that SU will adapt to the current hardware standards.
                              That's why I voted option 3, while I would really like to vote 2.
                              And in my personal view, yes, we need to speak up for what we wish for.
                              Who else will do it if we don't.
                              • N
                                nomeradona
                                i will still use it as modeller for my architectural vizualization. on the other hand im already looking on max and vray combo. because im doing mostly interior and exterior it seems to me that the alternative of exporting my shell sketchup model (without trees,plants,accessories for interior) but already with su materials. exporing 3ds wiht the option of not loosing the coordinates seems a very good workflow, then will do the max and vray render. at the moment its just a plan.
                                • EarthMoverE
                                  EarthMover
                                  I don't think anyone here truly wants to leave SU as our core modeler. In reality, I think we all just want to see the fulfillment of true potential. It's time for a blossoming evolution of inevitable development.
                                  The "people" have been working diligently to modify the go kart into a competitive race car. As we pull the race car up to the starting line, all the other "big name" cars look over and snicker. We'll show them! As the checkered flag drops, our beloved "hell on wheels" leaves all competitors in the dust. The fastest of the fast! Our machine is made for speed.....streamlined and efficient. We are lapping the competition. Going into the turn on lap 7 of 50...we start to loose speed. Slower and slower she gets, until she grinds to an abrupt halt. And there she sits. Out of gas. Out-matched, out-classed and humiliated. One day we'll beat these guys.......one day.
                                  Content Creator at Skapeup
                                    remus
                                    I couldnt have put it better myself.
                                    • StinkieS
                                      Stinkie
                                      @kwistenbiebel said:
                                      SU is not a standalone piece of software anymore , it is a 'platform' for 3td party software as well.
                                      And YES, Su needs to adress this!
                                      Precisely, otherwise it'll soon be nothing more than a bottleneck in people's workflow.
                                      • K
                                        kwistenbiebel
                                        And some more arguments for having High poly support /multicore / 64 bit in response to Coens post:
                                        RENDER ENGINES!
                                        Currently, most render engines are crippled at export phase because of SU limits (a maximum of 3Gb RAM supported, not large adress aware, no 64 bit, export within the same SU process (=not multicore support).
                                        Some render egines cost 1000 dollar and would definitely benefit from a better SU core code.
                                        @Coen: enough reasons here to have a better SU.
                                        I can't understand why you would not support this as a wish.
                                          ark
                                          I love sketchup!!
                                          I also love looking back to the time on my Commodore 64, but guess what, later I bought a Commodore Amiga. 🤓
                                          If software/hardware arn't updated/developed it's just a matter of time before it's history!
                                          Google is a large company fighting to gain marked, and I'm sure they didn't buy Sketchup just to let it die.
                                          • bigstickB
                                            bigstick
                                            I can't understand Coen's defensiveness. If you aren't moving forward, in effect you are moving backward.
                                            I agree with kwistenbiebel, yes I use the tricks, but using components means it is easy to add a huge amounts of detail to a model. When you have models which have lots of components of say, furniture with lots of curved forms (even tubular chairs for example) SU can get very slow indeed. When you work up the detail level internally and externally, add trees, some cars etc, your model gets really slow.
                                            I'm afraid I just don't buy the argument that SketchUp was only intended for modelling simple sketchy scenes. The program liberated us all from complicated tedious modelling packages and multiple 2d views, and we all loved it. Then when enough people get competent enough to fully exploit the software and ask for more, the response is,"Well you are pushing it beyond what it was intended to do".
                                            The things that are being requested are natural extensions to the program's capabilities. Seriously, obviously it's achievable. Max, Lightwave, Rhino, MoI and C4D can do it, why can't SU? I have mentioned elsewhere that Google employs some of the best and brightest people in the industry (and some others that are responsible for LayOut 😉 ) and this is what we reasonably ought to expect from one of the most powerful software companies in the world. There ought to be almost nothing they can't do.
                                            I think it is fair to say that SU raised the bar for everyone, and if it doesn't keep making good progress, it is going to lose users as the opposition (driven by commercial pressures) gets smarter and delivers what the market demands.
                                            I see nothing wrong with the voting options, and for people to think of leaving if development doesn't offer enough progress.
                                            I think it is sometimes easy to overlook the fact that we are here because we love SketchUp and want more from it. It will be a really sad day for me if I have to start using something else. I never had so much fun in my work before SketchUp came along, and it is a real joy to use - mostly. I'm not ready to jump ship yet, but the opposition is catching up, and I can see a scenario where I start to use another modeller.
                                            There is nothing wrong with prodding Google to focus their attention from time to time 😉
                                            • 2 / 3
