    [Plugin] Mullion, Screen or Grille tool
    11 Posts 8 Posters 17.0k Views 8 Watching
      digby dart
      Thank You tomot for another great ruby script. πŸ˜„
      • EdsonE Offline
        Edson
        @tomot said:
        As with the WindowGlass.rb (aka simple gazing tool) and the WindowGlassFrame.rb I used the "pick 3 points rectangle" approach to install a screen, grille, or mullions into any rectangular opening.
        where can WindowGlassFrame.rb be downloaded from? i could not not find it here nor anywhere.
        http://www.mahfuz.arq.br
          tomot
          404 Not Found
          (www.sketchucation.com)
          my plugins
          tomot
          • boofredlayB Offline
            boofredlay
            How is this different from Windowizer?
              dtrarch
              Tomot
              Very helpfull tool and thanks a bunch.
              dtr
                tomot
                Windowizer asks for 4 sided face to be selected first. While I use the "pick 3 point rectangle" method.
                This is not a criticism of how Windowizer works, it has more to do with my work flow.
                I design structures in SU using walls and slabs that have thickness. Then I punch openings in them for windows, doors, stairs etc., later I fill in those openings with the required components.
                I find the "pick 3 points rectangle' method the most natural way to fill in an opening. If I were to use Windowizer, I have to fill in the opening prior to running the script.
                My window routines are not offset only from the front face they are pushpulled so they look the same from the inside.
                But then again Windowizer can also draw windows that trapezoidal or parallelogram in shape which the "pick 3 point rectangle" method, cant imitate. So now you have an alternative way of doing windows πŸ˜„
                my plugins
                tomot
                  boofredlay
                  Thanks for the explanation, much appreciated.
                    cyan.archnet
                    very helpful script indeed!, thanks a lot!
                      JGA
                      Thanks very much!
                      Regards,
                      JGA
                        Jim
                        tomot has released an updated version of this plugin as part of a suite of WindowTools; see here:
                        404 Not Found
