⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Sandbox tool lost
6 Posts 2 Posters 1.5k Views 2 Watching
  • E Offline
    El.Russo
    Hi I am not that new to SU, but I have just started trying to use the sandbox tools. Unfortunately I can't find the sandbox tool. I went into Windows, preferences, Extensions and Sandbox Tools are checked. But, I cant find them anywhere... Help!!! I am sure its something quite stupid that I did or did not do, but I am stumed.
      Go to the menu View>Toolbars>Sandbox Tools. Make sure it is enabled there too.
      • E Offline
        El.Russo
        Hi Chris,
        Thanks for the quick response. Unfortunately I do not see a Sandbox tool in my Tools list. I have downloaded a lot of tools, perhaps one of them removed or replace the sandbox tools?
          Its possible that something is conflicting, but not likely. But who knows. Remove all plugins from your plugin floder. See if that helps. BTW Sandbox is not installed in the plugins folder so there is no chance of removing it if you pull out all other plugins.
          If you remove all plugins and sandbox starts working, then it is a conflicting script problem. Add them back one at a time until you find the culprit.
          • E Offline
            El.Russo
            Hey Chris,
            Thanks again, I don't know what caused the problem but what I did was repair the SU Installation and then everything started working normally. I now have my Sandbox Tools back....
            That was a weird one..
              ok good. Glad its back up and working,
