    Office building
    93 Posts 23 Posters 14.8k Views 23 Watching
    • StinkieS Offline
      Stinkie
      Thanks. That's just the default mat. Who needs textures?
      You ever used Maxwell for interiors? 💚 I want to to make a series out of this, and I'd like to finish it before the end of the decade. 💚
      Fun app, Vray. And all things considered, not that hard to use. Still prefer Maxwell for some things, though. (And Indigo - but it just uses too much RAM.)
      • StinkieS Offline
        Stinkie
        Why do I always have 5 things going at the same time? Must focus.
        http://img262.imageshack.us/img262/9867/63071538vx6.th.jpg
        • marked001M Offline
          marked001
          hey..that's very nice.. very detailed..
          http://www.revision21vis.com
          instagram: revi21on
          • StinkieS Offline
            Stinkie
            Just a wip, so far. Modeling away as we speak.
              marked001
              ..as i figured 👍
              instagram: revi21on
                kwistenbiebel
                I like your sense of detail Stinkie.
                Pure and straightforward.
                Does a rendering says something about ones personality?
                • StinkieS Offline
                  Stinkie
                  Amazing how fast Vray is. SU needs to be 64 bit, so Vray can be too!
                  http://img26.picoodle.com/data/img26/3/9/18/t_rrrm_9926648.jpg
                  Hm ... Let's hope not. I'd be an even bigger square than I thought.
                    marked001
                    damn...i was about to pull the trigger on a 64bit system....didnt even think about a compatibility issues...shooooott.
                    i really like this concept of having the model in a room... going to be cool..
                    instagram: revi21on
                    • StinkieS Offline
                      Stinkie
                      Eh? I didn't mean to imply that Vray doesn't work on a 64 bit system - it does just fine. 👍 I got one myself, and I totally recommend it. Works well with Crashwell! If you're going to get a 64 bit system, spend some cash on extra ram too. I got 16 gb - may look like overkill, but it comes in handy at times. No need to hold back when using MultiLight anymore.
                      Got both a series of Maxwell exteriors and Vray interiors planned. The Maxwells first, then the Vrays. Busy times ahead.
                      • StinkieS Offline
                        Stinkie
                        Still lots to do.
                        http://img27.picoodle.com/data/img27/3/9/19/t_updatem_4d69624.jpg
                          JuanV.Soler
                          I think you should quickly insert the desks and computers and tables and chairs in the Office´s closed interior walls, to make your fachade bright calmly.
                          good luck
                          • StinkieS Offline
                            Stinkie
                            Thanks for the tip, but no can do. Would, I suspect, not suit the mood I'm aiming for.
                            Detail:
                            http://img93.imageshack.us/img93/11/1mea6.th.jpg
                              JuanV.Soler
                              it was just a hint in case
                              dont worry and carry on
                              • plot-parisP Offline
                                plot-paris
                                I love the subtle, slightly glossy reflectiveness of the floors in your last exterior shot, stinky. truely beautyful.
                                this sterile, soemhow cold atmosphere of your renders reminds me of set designs of the movie "Equilibrium" (with Christian Bale and Sean Bean) - I like it! 👍
                                • StinkieS Offline
                                  Stinkie
                                  Thanks, herr W. The final image is rendering as we speak - and it will be for the next couple of days, I suspect. 😄
                                  There is in fact a cinematographic reference in the image - but it's not to 'Equilibrium'. Guesses, anyone? 💚
                                  • StinkieS Offline
                                    Stinkie
                                    Time's up. "Play Time", by Tati.
                                    Bridge based on drawing for "Play Time".
                                    http://img516.imageshack.us/img516/3919/brugskeniu3.th.jpg
                                    http://img516.imageshack.us/images/thpix.gif
                                    • StinkieS Offline
                                      Stinkie
                                      http://img87.imageshack.us/img87/1993/korreliguq8.th.jpg
                                      http://img87.imageshack.us/images/thpix.gif
                                      • StinkieS Offline
                                        Stinkie
                                        Abstraction is easy.
                                        http://img524.imageshack.us/img524/7259/99116850pn5.th.jpg
                                        http://img524.imageshack.us/images/thpix.gif
                                        • StinkieS Offline
                                          Stinkie
                                          Vray is fun.
                                          http://img296.imageshack.us/img296/3144/kkkkkkdf3.th.jpg
                                          http://img296.imageshack.us/images/thpix.gif
                                          • StinkieS Offline
                                            Stinkie
                                            Fast, too. 😄
                                            http://img296.imageshack.us/img296/6623/uuuvw5.th.jpg
                                            • 2 / 5
