    Office building
    93 Posts 23 Posters 16.1k Views 23 Watching
    • soloS
      Thats a pretty cool looking clay model effect.
      Now you are using Vray? 😄
      • StinkieS
        Stinkie
        Thanks. That's just the default mat. Who needs textures?
        You ever used Maxwell for interiors? 💚 I want to to make a series out of this, and I'd like to finish it before the end of the decade. 💚
        Fun app, Vray. And all things considered, not that hard to use. Still prefer Maxwell for some things, though. (And Indigo - but it just uses too much RAM.)
        • StinkieS
          Stinkie
          Why do I always have 5 things going at the same time? Must focus.
          http://img262.imageshack.us/img262/9867/63071538vx6.th.jpg
          • marked001M
            marked001
            hey..that's very nice.. very detailed..
            http://www.revision21vis.com
            instagram: revi21on
            • StinkieS
              Stinkie
              Just a wip, so far. Modeling away as we speak.
              • marked001M
                marked001
                ..as i figured 👍
                instagram: revi21on
                • K
                  kwistenbiebel
                  I like your sense of detail Stinkie.
                  Pure and straightforward.
                  Does a rendering says something about ones personality?
                  • StinkieS
                    Stinkie
                    Amazing how fast Vray is. SU needs to be 64 bit, so Vray can be too!
                    http://img26.picoodle.com/data/img26/3/9/18/t_rrrm_9926648.jpg
                    Hm ... Let's hope not. I'd be an even bigger square than I thought.
                    • marked001M
                      marked001
                      damn...i was about to pull the trigger on a 64bit system....didnt even think about a compatibility issues...shooooott.
                      i really like this concept of having the model in a room... going to be cool..
                      instagram: revi21on
                      • StinkieS
                        Stinkie
                        Eh? I didn't mean to imply that Vray doesn't work on a 64 bit system - it does just fine. 👍 I got one myself, and I totally recommend it. Works well with Crashwell! If you're going to get a 64 bit system, spend some cash on extra ram too. I got 16 gb - may look like overkill, but it comes in handy at times. No need to hold back when using MultiLight anymore.
                        Got both a series of Maxwell exteriors and Vray interiors planned. The Maxwells first, then the Vrays. Busy times ahead.
                        • StinkieS
                          Stinkie
                          Still lots to do.
                          http://img27.picoodle.com/data/img27/3/9/19/t_updatem_4d69624.jpg
                            JuanV.Soler
                            I think you should quickly insert the desks and computers and tables and chairs in the Office´s closed interior walls, to make your fachade bright calmly.
                            good luck
                            • StinkieS
                              Stinkie
                              Thanks for the tip, but no can do. Would, I suspect, not suit the mood I'm aiming for.
                              Detail:
                              http://img93.imageshack.us/img93/11/1mea6.th.jpg
                                JuanV.Soler
                                it was just a hint in case
                                dont worry and carry on
                                • plot-parisP
                                  plot-paris
                                  I love the subtle, slightly glossy reflectiveness of the floors in your last exterior shot, stinky. truely beautyful.
                                  this sterile, soemhow cold atmosphere of your renders reminds me of set designs of the movie "Equilibrium" (with Christian Bale and Sean Bean) - I like it! 👍
                                  • StinkieS
                                    Stinkie
                                    Thanks, herr W. The final image is rendering as we speak - and it will be for the next couple of days, I suspect. 😄
                                    There is in fact a cinematographic reference in the image - but it's not to 'Equilibrium'. Guesses, anyone? 💚
                                    • StinkieS
                                      Stinkie
                                      Time's up. "Play Time", by Tati.
                                      Bridge based on drawing for "Play Time".
                                      http://img516.imageshack.us/img516/3919/brugskeniu3.th.jpg
                                      http://img516.imageshack.us/images/thpix.gif
                                      • StinkieS
                                        Stinkie
                                        http://img87.imageshack.us/img87/1993/korreliguq8.th.jpg
                                        http://img87.imageshack.us/images/thpix.gif
                                        • StinkieS
                                          Stinkie
                                          Abstraction is easy.
                                          http://img524.imageshack.us/img524/7259/99116850pn5.th.jpg
                                          http://img524.imageshack.us/images/thpix.gif
                                          • StinkieS
                                            Stinkie
                                            Vray is fun.
                                            http://img296.imageshack.us/img296/3144/kkkkkkdf3.th.jpg
                                            http://img296.imageshack.us/images/thpix.gif
                                            • 2 / 5
