Positioned textures
help me! i can't get an appropriate render of positioned textures (images used as textures and deformed) with podium and turbo sketchup. I've adapted the textures to the faces (whit TEXTURE POSITION) and i see it in visualization mode, but when i render it the texture is repeated many times in the face.
thank you for your help -
Try exploding the component/group then re-apply texture and see if it works.
i haven't applied textures to group or components but on a simple surface.
If you have problem with Podium can you call in the Podium forum ...It would be useful if you post skippy with your post.
