    Add entity to a group
    10 Posts 5 Posters 752 Views 5 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all
      Is there a way to add an existing entity to a new group created by a script ?
      I haven't found anything that sounds like "new_group.add_entity(old_entity))...
      Thanks in advance,
      DB
      • W Offline
        wikii
        entities.add_group(old_entity)
          Matt666
          Hi Didier !
          Perhaps create a group with existing group and entity to add, and explode the existing group inside the new...
          Tu pourrais créer un nouveau groupe avec le groupe existant et l'entité à ajouter, puis exploser l'ancien groupe ?
          Le problème est si tu veux à tout prix garder le groupe existant (genre si tu as un nom, etc...)
          sel.add groupe
          sel.add entite
          model.active_entities.add_group sel
          groupe.explode
          Frenglish at its best !
          My scripts
            RickW
            Be careful, though, as you cannot add existing entities to a nested group. The group will exist in model.entities, and not as a nested group.
            model = Sketchup.active_model
            entities = model.entities
            group1 = entities.add_group
            face = group1.entities.add_face(points) #points should be defined, of course
            #  the following group, while coded to be a nested group, will not be nested
            group2 = group1.entities.add_group(face)
            Google is aware of the situation, but I doubt we'll see a fix before v8.
            RickW
            [www.smustard.com](http://www.smustard.com)
              Matt666
              What's the problem if you create a new group with existing group and the entity to add, and AFTER you exploding the existing group inside the new group ??? All entities of the exploded group are in the new group, with the entity to add ! 😄
              You don't agree ?
              My scripts
                Didier Bur
                Thanks all,
                Sketchup.active_model.entities.add_group(old_entity) works 👍
                Sketchup.active_model.entities.add_group(Sketchup.active_model.selection) also works !
                Sketchup.active_model.entities.add_group([entity1,entity2,...,entityN]) works too.
                Could be put in the Wiki, because this is not mentionned in the regular doc.
                DB
                  Matt666
                  Ah ok... I have not read the question enough... 😳 😳 😳
                  I understood : "Is there a way to add an existing entity to a existing group created by a script ?"
                  Hum hum 😕
                  My scripts
                    Jim
                    @didier bur said:
                    Thanks all,
                    The most recent documentation has been updated. See below for a link.
                    http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10569&hilit=+ruby+doc+
                      Didier Bur
                      Oops, apparently the problem for me isn't to know if an information exists, but to know where it is...
                      DB
                        Jim
                        This is the documentation page I use - it's the most up-to-date:
                        http://groups.google.com/group/SketchUp-Plugins-Dev/web/Ruby-classes.html
                        Todd and Rick get all the credit for updating the docs - it's a thankless chore, no doubt.
                        I wish there was a way to see what changes have been made to the documentation. I've asked that document updates be logged for us, but maybe I'm asking too much.
