Add entity to a group
10 Posts 5 Posters 630 Views 5 Watching
    Didier Bur
    Hi all
    Is there a way to add an existing entity to a new group created by a script ?
    I haven't found anything that sounds like "new_group.add_entity(old_entity))...
    Thanks in advance,
    DB
    • W Offline
      wikii
      entities.add_group(old_entity)
        Matt666
        Hi Didier !
        Perhaps create a group with existing group and entity to add, and explode the existing group inside the new...
        Tu pourrais créer un nouveau groupe avec le groupe existant et l'entité à ajouter, puis exploser l'ancien groupe ?
        Le problème est si tu veux à tout prix garder le groupe existant (genre si tu as un nom, etc...)
        sel.add groupe
        sel.add entite
        model.active_entities.add_group sel
        groupe.explode
        Frenglish at its best !
        My scripts
          RickW
          Be careful, though, as you cannot add existing entities to a nested group. The group will exist in model.entities, and not as a nested group.
          model = Sketchup.active_model
          entities = model.entities
          group1 = entities.add_group
          face = group1.entities.add_face(points) #points should be defined, of course
          #  the following group, while coded to be a nested group, will not be nested
          group2 = group1.entities.add_group(face)
          Google is aware of the situation, but I doubt we'll see a fix before v8.
          RickW
          [www.smustard.com](http://www.smustard.com)
            Matt666
            What's the problem if you create a new group with existing group and the entity to add, and AFTER you exploding the existing group inside the new group ??? All entities of the exploded group are in the new group, with the entity to add ! 😄
            You don't agree ?
            My scripts
              Didier Bur
              Thanks all,
              Sketchup.active_model.entities.add_group(old_entity) works 👍
              Sketchup.active_model.entities.add_group(Sketchup.active_model.selection) also works !
              Sketchup.active_model.entities.add_group([entity1,entity2,...,entityN]) works too.
              Could be put in the Wiki, because this is not mentionned in the regular doc.
              DB
                Matt666
                Ah ok... I have not read the question enough... 😳 😳 😳
                I understood : "Is there a way to add an existing entity to a existing group created by a script ?"
                Hum hum 😕
                My scripts
                  Jim
                  @didier bur said:
                  Thanks all,
                  The most recent documentation has been updated. See below for a link.
                  301 Moved Permanently
                  (www.sketchucation.com)
                    Didier Bur
                    Oops, apparently the problem for me isn't to know if an information exists, but to know where it is...
                    DB
                      Jim
                      This is the documentation page I use - it's the most up-to-date:
                      Error 404 (Not Found)!!1
                      (groups.google.com)
                      Todd and Rick get all the credit for updating the docs - it's a thankless chore, no doubt.
                      I wish there was a way to see what changes have been made to the documentation. I've asked that document updates be logged for us, but maybe I'm asking too much.
