    Exporting model in 3DS broken
    4 Posts 3 Posters 924 Views 3 Watching
      kilgo
      I am running a Mac with system 10.4.11 and I remember a while back, being able to export 3DS files for a render application I use. But now when I try to export the model for 3DS I cant access the "Options" radio button, although it is active and I can click it, it just doesn't take me to another dialog. Further-more, if I choose "export" the activity dialog just keeps cycling and never saves the file. I am not using anything large just a test file with a simple 5x5 cube.
      Anyone have a solution?
        Kilgo,
        I remember a glitch in one of the Mac builds that prevented people from exporting to 3ds. Do you have the latest version of SU?
        • Chris FullmerC Offline
          You have to trash the plist. It has gotten corrupted. If you need more detailed help, try searing the forum for plist. It should bering up a few threads where this is explained better.
          Hope that helps,
          EDIT: Here is the path to the plist:
          "The path of the OS X file (the .plist) is Users/Username/Library/Preferences, where Username represents your user name."
            kilgo
            Thanks Chris...
            ...but that didn't solve it. I don't know why.
            I was looking in the "About Plugins" menu under the sketchup menu and noticed that i have a plugin called "3DS Export". I can't find this plug-in, does anyone know were it might be located? And is there a separate preference for this plugin, maybe that has something to do with the problem?
