How to give a thickness to a surface?
Hi everybody,
I'm searching for a script that gives choosen thickness to a group of surfaces. Does it exist? I attach an image of the object to which I wish to give a thickness (steps). In addition, is it possible to transform the lines into cylinders?
Thank you for your help.
vivo
TIG's TubeAlongPath script would deal with the lines for you.
You said the steps are groups. If you would make a component of one and copy it to make the others, you could edit one of them to give thickness and all the others would be edited at the same time. I would make components of the lines-tubes as well to prevent the file size from going through the roof.
additionally
i see that steps of stair have texture, so right click at step and select by color/texture.
Then D.Bur's Projections ext.(http://www.crai.archi.fr/RubyLibraryDepot/Ruby/RUBY_Library_Depot.htm)>>Faces operations or use Joint Push Pull from Fredo - Visual Edition - http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708&st=0&sk=t&sd=a#p42783@unknownuser said:
D.Bur's Projections ext.>>Extrudes lines to cylinders
Ok, thank you, it works, the probleme was that i made group inspite of components...stupid error. In addition, do you know a script which makes it possible to reorientate the juxtaposed faces the same way (some normals are inverted), so that I can extrude the steps with joint push pull from fredo?
Have you tried opeing the group/component, right clicking on a face that is oriented correctly and then choosing Orient Faces?
ok, it works. Thank you very much!
