    Simple 2D spiral
    24 Posts 7 Posters 6.1k Views 7 Watching
    • T
      ticoloco
      Dears,
      I am looking for a simple (Ruby?) routine to create a 2D spiral which is extendable. Something like define 2 circles, segments and number of rotations.
      In the tutorials I found a lot about staircases and p.e. screw2.1 (which works nice, but is not extendable in 3D).
      Any help?
      • T
        ticoloco
        No, not necessarily.
        What I need is to define frequently spirals which I pretend to join by lines at the ends to get a helical area in 2D.
        • TaffGochT
          TaffGoch
          ticoloco,
          I'm confused. A helix is a 3D object. How do you propose to depict it in 2D?
          Anyway, see if the discussion here, about helices, helps you:
          http://groups.google.com/group/SketchUp/web/faqs-for-learning-more-advanced-tips-and-techniques#TweakSclupt
          The discussion includes a mention of 'drawhelix13.rb' available at The Ruby Library Depot
          Taff
          "Information is not knowledge." -- Albert Einstein
          • boofredlayB
            boofredlay
            It may not be exactly what you need but check out the Spiralizer by Armanisoft.
            404 Not Found
            (www.armanisoft.ch)
            You can export the dxf files and import them directly to SU.
              remus
              Does it have to be in ruby? If not you could just create your first spiral and then copy it up (move+ctrl.)
              edit: sorry, i completely skimmed over the 2D bit, ignore the stuff above.
              • T
                ticoloco
                I do not want a 3D helix, I want a simple 2D spiral (with the aim to push).
                Are there any possibilities within SU? It should be much simplier to program than a helix!
                • G
                  GreyHead
                  Try Draw helix 13 and set the pitch to 0 to keep the helix 2d.
                  Or K tools will allow you to define your own equation for the spiral.
                  Bob
                  • T
                    ticoloco
                    Thank you Greyhead,
                    the K-tools helped. But I still have the problem, that the resulting object seems not to be joinable into an area.
                    What I want to do are scrolls (rolled rectangles). Any ideas?
                    Thank you for your time
                      remus
                      You could use didiers projection tools to turn it in to an extruded face (http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm name: projection_v6.rb) or you could start with a bir rectangle, slice it up in to lots of small rectangles and then incrementaly rotate them. See tut for more details.
                      Add more seqments to the starting rectangle to increase smothness of the scroll.
                      • G
                        GreyHead
                        For scrolled rectangles see this post - you'd need to delete some unwanted stuff.
                        Bob
                        PS No time to test it now - I'll try later.
                        • TaffGochT
                          TaffGoch
                          Something like these?
                          If not, do you have a photo of what you're trying to achieve?
                          Taff
                          • B
                            bbwolf
                            Hello there
                            @TaffGoch
                            That´s exactly what I want to do. How´d you create this?
                            Looking for how to do a spiral in SU for hours now, but can´t
                            seem to find an answer.
                            What´s KTools btw, anyone?
                            • GaieusG
                              Hi Wolf,
                              kt_tools##.rb (for different mathematical shapes) and drawhelix##.rb (for spirals) are ruby scripts used as plugins in SU.
                              You can download them here.
                              • B
                                bbwolf
                                Hey Gaieus
                                I really hate to sound like a total noob but when I try to download the stuff I get a website with ALL the code. What am I ´sposed to do with that?
                                I tried to put in a text file but my mac flatly refuses to change the suffix to rb.
                                wth? Any ideas? Would be great. Clock is ticking for me and that sucks.
                                Thanks everybody
                                • GaieusG
                                  Don't worry about sounding like a noob - after all we are in the Newbie Forum (and we all had to start somewhere).
                                  Anyway, I'm not a Mac user so I'm not sure everything will work the same way;
                                  If you click on the script and it returns the code, you can select all and copy > Paste it into a simple text editor (not a word processor!) then save it under the Macintosh HD/Library/Application Support/Google Sketchup 6/SketchUp/Plugins folder with the exact name it has on the site.
                                  You can (on PC) also just right click on the link and save it to the same place but with rb extension.
                                  • GaieusG
                                    For the easy spirals, download the drawhelix.rb as well (it also has several versions).
                                    • B
                                      bbwolf
                                      okay I managed to get k_tools_50.rb to run in my SU
                                      just read yer answers - found it before 😎 <
                                      Now, how do I get the spiral done, please? If I´d known math I wouldn´t
                                      have become a designer in the first place.
                                      See attached pic for what this stupid muppet sees and tell what to do, please
                                      • B
                                        bbwolf
                                        whelp
                                        I´ll do that right now. Keep ya posted on the process.
                                        Thanks so much
                                        • B
                                          bbwolf
                                          It works! Saved by Gaieus! Thangk yew. Thangk yew verry mudch. 😎
                                          • GaieusG
                                            No, these are just the first steps in discovering the wonderful and exciting world of pluins! 😉
