    Slice Through Cylinder
    20 Posts 3 Posters 4.1k Views 3 Watching
      What twisted form?
        Squeaky2011
        Twisted like a figure of eight
          You practically make this just like the simple torus - just set up the follow me path accordingly.
            Squeaky2011
            Thanks ..... My problem is not actually doing a drawing of a twisted torus .... although I am still very low on the SU learning curve .... but I am only wanting SU as another tool to aid construction of a wood model.
            What I wish to do is to make a 'component' that has precise measurements .... then arrange these components in SU to give me a 'twisted torus'.
            I am expecting to have to do a great deal of experimentation, on paper, with SU, in order to achieve what I want .... However, I do feel that this is a more better method than actually making the componts (in wood) and then experimenting.
            The model torus, shown earlier in this forum, was made up from 36 X 10 degree slices from wood that was glued together as shown in this attachment.
            I would imagine that I will have to rotate each slice, by a number of degrees, to achieve the wanted results.
            If you have any ideas on the above method please tell me
            Squeaky
              Yes, I guess that's exactly what the method should be. You can do it in an automated way with the "Radial array" (read about halfway through the page):
              http://download.sketchup.com/OnlineDoc/gsu6_win/Content/D-Modification_Tools/ModTool-Rotate.htm
              You can also define how many segments of the circle you want in different ways (they apply to polygons as well):
              1. after creating the circle, right click on its edge and go to Entity info then change the segment count there
              2. or after drawing the circle, just type the desired number of segments followed by the letter s (for segment) and hit enter.
                Squeaky2011
                Hi Watkins, and anyone else who knows
                It may a very dumb question .... How do I do an section plane at an angle
                Similar to the one you showed earlier.
                Squeaky
                • W Offline
                  watkins
                  If you want to create a section plane at a given angle then first create a surface with the desired angle. Let's call this the angle plane. Select the section tool and place it on the angle plane. Hold down the shift key and move the section plane to the object you are trying to section. Click on the object and then release the shift key. Select the section plane and move it with the move tool.
                  If you want to section only the object, then make the object a group or component first; then, double click on it to edit it, select the section tool and repeat the last bit of the above.
                  Regards,
                  Bob
                  Section plane.skp
                    Squeaky2011
                    Squeaky Again !...... with more problems .... sorry!
                    O.K. I have managed to cut a slice through the cylinder... thanks to a lot of help! See attachment
                    My next question is ...... How do I use multiple copies of this slice?
                    My idea is to build up a model with a number of these slices glued together
                      You can only have one section plane active in a given context (i.e. without groups/components or within a component/group). So what you need to do is to group your section plane with your model then insert another section plane, now group this with the previous group etc.
                      This way you can even create animated section planes. Search the Tutorial forum below and you will find some nice examples.
                        Squeaky2011
                        Thanks....
                        As seen in attached... I have done a very rough drawing of what I need .... Now how do I get rid of the clutter like 'section planes' and use multiple copies of the component?
                          There is a Toggle section planes button in the toolbar which "hides" the section planes (see image). Also available menu iten in the View menu.
                          If you have made a component of the geometry and the section planes, it should appear in your component browser. From there you can insert as many instances as you like as well as you can copy it with the Ctrl+Move tool.
