    My recent tries
    135 Posts 37 Posters 33.0k Views 37 Watching
    • majidM
      majid
      thankx Jakob , for comments . at the last image i'd tried to sumulate water using just KT tecturs ( in fact i'dnt used any bump or other maps in su ....) so it was an interesting experience for me myself....and bkz i was tring to simulate near shore sea ...then it is not so clear water.... but the whole seen ( maybe soon i'l send some renderes ) seems to be more real .
      about the 2nd image i 'd used 2 type of faces beside each other and then used diferent bump map for each other so that they seem more real ( not flat and non-real glasses ).u can read more here :at kt forum
      http://www.kerkythea.net/joomla/index.php?option=com_wrapper&Itemid=76
      • majidM
        majid
        i thought my recent works have no new thing , but maybe interested to be seen . so i desided to share them . hopr u joy
        http://i37.tinypic.com/w80ua9.jpg
        http://i33.tinypic.com/eqchoi.jpg
        http://i34.tinypic.com/332mj9u.jpg
        all modeled in su , rendered using kt , and just 4 fun
        majid
        • majidM
          majid
          pure render just some detailes by ps
          • B
            bubbalove
            So wheres the brush? Or are these finger paints?
            "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
            • majidM
              majid
              ok bob , here r the brushes ...
              • Mike LuceyM
                Mike Lucey
                Majid, you have definately become a Master 👍
                • majidM
                  majid
                  tanx mike , here we have a friendly forum that helped me alot ! thanx to all masters
                  • majidM
                    majid
                    i changed some kt settings , and here is the result .
                    cheers
                    http://i38.tinypic.com/11m7vck.jpg
                    • majidM
                      majid
                      by now i think my best interior render is this kitchen ( 2 h kt render preset 20 )
                      i'm trying other lighing test ..and soon ll uplod it
                      cheers
                      http://i35.tinypic.com/2dumq69.jpg
                      • majidM
                        majid
                        this is an over night result,some change in lights . just noise reduction ( a bit of lightening over the hood part )
                        http://i35.tinypic.com/2czsgo8.jpg
                        • plot-parisP
                          plot-paris
                          nice kitchen model, majid.
                          i like the lighting effect on the lampshade. did you use several light bulbs within the lamp for that?
                          the workface, especially on the left looks a bit sterile; perhaps because of the utterly sharp edges. or maybe a slightly different material would help.
                          • majidM
                            majid
                            thanx dear Jakob for comments . i used several lamps and also whit several shadow color to have a colorish space theme.
                            • utilerU
                              utiler
                              @majid said:
                              here are some recent render of a monumental building
                              با کمی ویرایش فتوشاپ . این آخرین کارائیه که واسه "هیراد نقش" انجام دادم
                              http://i27.tinypic.com/ka1mdi.jpg
                              http://i27.tinypic.com/vi0ksw.jpg
                              http://i32.tinypic.com/j58pbn.jpg
                              http://i29.tinypic.com/21cfkic.jpg
                              http://i28.tinypic.com/w1fuhf.jpg
                              Hi Maj,
                              I really like your edge styles here, way cool.... also your coloring technique; reminds me of TDT of yesteryear.... for those of you who can remember.
                              Also your proficiency with KT, I am considering which way to go at the moment, KT or SUPodium.... your results are making it difficult to decide!!!
                              Thanks for your generosity in sharing your work.
                              Just Curious...
                              • majidM
                                majid
                                kt and podium have the same ENGINE !!! but obviosly kt has more control and is eaasy to learn ( whit a friendly and helpful forum ). so i suggest KT , it has lots of render presets and u can also change the presets .... lots of control over the material settings ....
                                also KT has unbiased and biased render settings..
                                frensel ramp over material
                                • utilerU
                                  utiler
                                  Thanks for the tip; I'm going shopping.....
                                  Just Curious...
                                    Julius
                                    cool material! would you share some more details?
                                    • majidM
                                      majid
                                      i tried KT physical sky over a true-scale model ( noise removal + light effects using ps ).here is the result cheers
                                      • majidM
                                        majid
                                        dedicate this work to all who helped me on sketchucation and KT forum, to participate in 3rd celeberation . cheers majid
                                        • G
                                          geh4evr
                                          Those are lovely models, You should give Hypershot a try, It's very good for the renders you'd do.
                                          • majidM
                                            majid
                                            i can not pay via web and so just use fre softwares 😄 . and also love kt .. here r the last try ... hope u joy
                                            http://i37.tinypic.com/2d27ol.jpg
                                            http://i36.tinypic.com/2qc1o5y.jpg
                                            • 4 / 7
