    This does not appear to be a Sketchup model
    8 Posts 5 Posters 16.3k Views 5 Watching
      steve6
      I hope someone can help me--I posted this on the Google Help page as well--I'm baffled! I've been trying to download samples of entourage from various sites which sell such items. I just tried a bush jpeg--I unzipped it, sent it to Components in SU--it's there in name, but nothing is there to open. So I thought I would unzip the file to my desktop first--I did so, tried to open it, and it says, "this does not appear to be a Sketchup model"--and it won't open. The same happens if I try to download a jpeg from one of the entourage sites. And it happens sometimes when someone e-mails me a photo.
      What is going on? How can I stop this? I guess somehow SU is trying to open the jpeg, but why?
      • RayOchoaR Offline
        RayOchoa
        click and drag it into sketchup
        CaR DeSiGnS bY mE
        http://ray-ochoa.com
          Pagan
          Right mause button on photo,than go on properties.
          There go on change and select program depend what you have,windows paint or something similar.
          Jpeg is not a model it's a photo,you could import into sketch up but not open it with sketch up.
            steve6
            I don't want to open it with Sketchup. I want to open various jpegs (by double-clicking, for example), but this message keeps coming up and I can't open them (unless I want to use the picture and fax viewer, for example, which I don't).
              Kenny
              Steve
              Pagan has correctly explained what's required as far as I understand your query but possibly I'm missing something. Am I right in saying when you double click a JPEG, you get the message "this does not appear to be a Sketchup model"? A JPEG of course isn't a Sketchup model but for some reason it is treating it as such but not opening it. It may possibly be due to you originally saving the JPEG's in your Sketchup components file.
              If you want to open a JPEG however you have to open it with some form of JPEG viewer whether that's the picture and fax viewer, Photoshop, Irfanview etc etc. You have to change your file association to a programme that you want to use. If it's not the picture and fax viewer then something else. Pagan did explain this but for a full explanation go to:
              http://support.microsoft.com/kb/307859
              Hopefully that should address your problem. If you want to use a JPEG in SketchUp you should import it as an image from within SketchUp. I hope that helps.
              Kenny
              http://www.townscapesolutions.co.uk/
                Maybe somehow your system associates jpeg files with SU. Try right clicking a jpeg file, go to the bottom most menu (Preferences or what - I have a Hungarian version of Windows) and in the popup menu there must be an "Associate" (or what) item where you can set the file association to your image viewer or editor.
                If you want to import an image into SU instead, go to File (menu) > Import and choose the image file type from there.
                  steve6
                  Thanks for helping on this! No, I haven't saved the jpegs in SU at all. For example, a friend e-mailed me a jpeg of a drawing he did--when I tried open it by double-clicking on the paperclip in OE, the message appeared. If I download a jpeg from a webite, the same. before I installed Sketchup, all I had to do to open these kinds of files was to double-click on them. I'm trying to get that feature back!
                  I will try your "associate" idea--thanks!
                    steve6
                    That did it--thanks! Apparently, Sketchup had installed itself to open jpegs, so I changed the settings and it's back to normal!
