    Computer cleaning
    13 Posts 10 Posters 994 Views 10 Watching
      johnsenior1973
      @glenn said:
      How often do you remove the case & dust inside your computer?
      I've aligned my PC cleaning regime with Haley's Comet.
      • boofredlayB
        boofredlay
        I try to do mine every other month or so... I guess I need to do it soon.
          remus
          I tend to do mine whene ever i can be bothereed really, so every few months i suppose.
          On a slightly related note, my friend didnt clean his for 3-4 years, when i went to clean out their old graphics card their were solid lumps of 'dust'.
            Ross Macintosh
            Everytime I smell something melting in there - or when the computer slows down. Whichever comes first! That works out to about once a year. Not good since the tower is sitting on the floor that only gets a vacuum once-a-week.
            I know - I know - I should clean the case (and the floor) more frequently. I also shouldn't have the case on the floor and I should exercise more and drink less. I know - I know.
              marne
              I clean my Notebook every 2 weeks. After every cleaning there is a noticeably faster spindown of the ventilators after a hot job. But take care not to let fans spin from the airflow of the vacuum cleaner or the compressor(<-my preferred method). The induced tension may damage some parts on the board...
              Happy cleaning
              Marne
              • plot-parisP
                plot-paris
                every time I get a new piece of hardware, I open my computer. is is allways a shock and I promise myself to clean it properly soon, then take out the grown dust carpets, put them to the used clothes collection pile and start testing the new hardware... πŸ˜•
                I know, I should exercise a bit more discipline with my new laptop (going to arrive in a view days πŸŽ‰ )
                by the way: how do you clean your notebook, marne? you don't actually open it, do you?
                  marne
                  Its easy Jakob,
                  only every second time i open the nb. Mine has two clips below the display, if i release them i get direct access to the fans and could clean them without screwing around. But i think there are not much nbs which make it so easy to the user.
                  The other times i just use a compressor with a kind of pistol (like the one in the attachment). This makes the cleaning procedure very comfortable and you can see the dusty-loads streaming out of the ventilation slots when pressing the air through the nbcough. It only takes a few seconds.
                  But be aware: first as already said, you have to avoid that the fans start spinning from the airflow (i use a bend up paper clip for fixing), because they will generate electricity that may blow up some sensitive parts on your mainboard! Your computer won't be the first one, died on a cleaning. And second you may take care that this strong air-beam(?) doesn't hit the fixed fan directly - it may buckle the shaft drive.
                  Try to monitor the temperatures of your components if you don't already do this. I use this one http://www.pbus-167.com/ or speedfan.
                  You may compare the temps while working with it now (brand new πŸ˜„ ) and after 4 weeks of usage. For me it makes a 5Β°C difference while rendering f.e. (CPU around 73Β°C before and 68Β°C after cleaning while running on 2 of 2 cores, nevertheless both temps are way too hot 😞).
                  for a cleaner environment πŸ˜‰
                  no, this is not rendered :lol:
                  • plot-parisP
                    plot-paris
                    I know, I know; I only wear one pair of shoes, and that for a whole year!
                    this post would have slipped my attention in another thread in the corner bar
                    could someone remove this spam-bot?
                    • eevaE
                      eeva
                      done! i deleted the post 🀒
                      • plot-parisP
                        plot-paris
                        thanks, Eeva.
                        somehow they seem to have found a small hole in the defence the last days 😞
                        • GaieusG
                          Well, anyone can find those holes (called 'registration') but as I see the team never leaves a spammer to me (if you knew what a nice feeling is to press the 'Ban' button on them) πŸ˜‰
