    Attribute dictionnary
    7 Posts 4 Posters 639 Views 4 Watching
      Matt666
      Hi all !
      Juste one little question : How can I find name of a dictionary in ruby ?
      I tried that :
      ent.attribute_dictionary
      But a name is required... And I don't know dictionnary name...
      Thank you !
      Frenglish at its best !
      My scripts
      • fredo6F Offline
        Matt,
        You can get the dictionnary, via the model (either existing or to create a new one)
        model = Sketchup.active_model
        attributedictionary = model.attribute_dictionary name, create
        This is described in the Ruby doc.
        Be careful to choose your own name to avoid interfering with other dictionaries used by some scripts.
          Matt666
          Salut Fredo !
          Ce que je veux c'est regarder les dictionnaires existants, par en créer un... 😉
          I just want to get information from an existing dictionary, not to create it !
          Et pour regarder, il faut connaitre le nom....
          Merci à toi !
          My scripts
          • Al HartA Offline
            Al Hart
            If you want to see what dictionaries are already on an entity use:
            entity = model.selection[0] # get selected entity
            entity.attribute_dictionaries.each { |dict| puts dict.name}
            If you want to see what attributes are stored on a component definition, use:
            entity.definition.attribute_dictionaries.each { |dict| puts dict.name}
            Al Hart
            IRender nXt from Render Plus
            • fredo6F Offline
              Matt,
              Then, you just need to loop through the collection of dictionaries of the model
              list_dico = model.attribute_dictionaries     # List of all dictionaries
              list_dico.each do |dico|
                 dico.each_pair do |key, value|
                     #do what you want with the key and value
              • Didier BurD Offline
                Didier Bur
                Salut,
                Attr dictionaries list (attached to model, not to a particular entity), along with keys and corresponding values, output in the console:
                def list_ad
                  ads=Sketchup.active_model.attribute_dictionaries
                  if ads
                     ads.each do |ad|
                      puts "Dict; " + ad.name + "\n"
                      puts ad.keys
                      puts ad.values
                  else
                     UI.messagebox("No dicts in model")
                Dicts are hash, thus Hash.methods can be used.
                Les dicts sont des Hash. Les méthodes de Hash peuvent donc être utilisées.
                DB
                  Matt666
                  Ok thank you all for your excellent answers !
                  My scripts
