    Plane on a coneyor belt
    110 Posts 14 Posters 14.9k Views 14 Watching
    • plot-parisP
      plot-paris
      if we asume that the conveyor belt always keeps the same speed as the airplane's forward motion (which is, what they want, if I understood correctly), thus keeping the jet at zero speed relative to it's surroundings, it can not take off, no matter if it is an aircraft with a propeller, jet engine or even rocket propulsion.
      the only thing that matters is, like explained several times already, the relative speed of air rushing past the planes' wings.
      If we use a jet fighter instead of a glider it only means, that we need even more speed to take off, because the wings provide a smaller surface.
      and because the formula is
      air-pressure x wing-surface
      (at least I think it is like this πŸ˜‰ ) the variable air-pressure needed to increase if the wing-surface is reduced.
      you can think it the other way arround. if a plane flew happily through the sky and suddenly a big wall (lets say a ufo) would decide to fly directly in front of it with the same speed, thus providing slipstream, the poor plane would simply fall out of the sky... πŸ˜„
      • Chris FullmerC
        @plot-paris said:
        ...thus keeping the jet at zero speed relative to it's surroundings, it can not take off, no matter if it is an aircraft with a propeller, jet engine or even rocket propulsion.
        the only thing that matters is, like explained several times already, the relative speed of air rushing past the planes' wings...
        Yes, but your thinking of it how I was too. Its important to note that the question doesn't say that the engines are off, it just says that a conveyor belt keeps it from moveing forward. So the engines are on full blast, thereby sucking the air towards them. So the plane is not standing still relative to its surroundings, because its surroundings are rushing towards it through its propellers/jet engines at a high enough velocity to achive lift, even while sitting still on a conveyor.
        • soloS
          If it's a Harrier then it WILL take off!
          http://img362.imageshack.us/img362/8499/harrierneargroundgv7.jpg
          • Alan FraserA
            Alan Fraser
            The problem is the instinctive analogy with a car...which would remain motionless in such a situation. In fact, because the plane gets its propulsion from its props/jet turbines, as soon as the engine is fired the plane will move forward through the air, regardless of what the conveyor belt is doing. The conveyor could be moving at light speed, all it will do is make the plane's wheels spin faster than they normally need to.
            A much closer analogy would be if you were wearing roller skates and attached to a winch which pulled you forward at 30 mph, while the conveyor was rolling backwards at 30 mph. The result would be that you would still move forward at 30 mph...but the skate wheels would be doing 60.
            3D Figures
            • P
              pav_3j
              just had a full blown office argument about this, for about an hour on an off, (and this is no exageration).
              only one other person in my office agreed with me on the plane being able to fly, and together, we had to convince the other 6 in the office they were wrong.
              not an easy task, but one i enjoyed none the less.
              at one point, someone went to their car and got out a toy car ( i presume their kid left it in there!) and did a demonstration as to why it would not work.
              after it was pointed out to him that a cars propulsion was very different from a planes he totally understood. and also cherried up like i have never seen before, it was hilarious!
              thanks remus, hours of fun!
              pav
              Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
              • plot-parisP
                plot-paris
                I am afraid I have to disagree with you, Alan.
                important to understand is, that if the plane's engines were turned off and the conveyor would start to move, the plane would be moving backwards.
                only because it is pushing itself forward with it's engines, it is able to prevent from moving backward, but standing still, relative to the spectators (because, if the plane speeds up, so does the conveyor belt - that is the whole idea after all).
                Chris, you are right that the plane is sucking air through it's engines and therefore creating a stream towards itself. but essential is, that it is sucking the air through the engines. therefore no stream of air hits the wings, that would give the plane upwarts thrust.
                the only way to move upward is to direct the stream of air towards the ground (which solo's harrier does). but that would mean cheating in the case of this experiment πŸ˜„
                to make it more clearly, take pav's idea of attatching wings to your arms and running on a treadmill. you can run as fast as you can, you will most certainly not be able to take off.
                if you now jump from the treadmill to the side on the ground, you will discover, that your relative speed to your surroundings (and therefore to the air surrounding you) was zero!
                • P
                  pav_3j
                  hold on a sec, i added an edit to my post, i believe that the plane WILL take off.
                  running on a treadmill is very different as the propulsion is from the legs.
                  the propulsion for the plane is not from the wheels, but the jet, or prop.
                  the air would pass over and under the wings and create lift, all that the conveyor belt does is negate the planes forward movement realtive to the ground, which makes no difference anyway. you need to look at the planes movement relative to the air around it.
                  the plane will attain lift.
                  pav
                  • plot-parisP
                    plot-paris
                    unfortunately you are wrong in this case, pav.
                    the air is NOT flowing past the wings. the air is flowing through the jet engine.
                    you need a big fan in front of the plane to create an air flow past the wings...
                    otherwise you would not be able to stand on a plane's wing (beside the engine) when it is accellerating (well, if there were no conveyor belt, you would obviously fall down from the accelleration πŸ˜‰ ).
                    • david_hD
                      david_h
                      I have to draw things in order to understand them . . ..I think I solved this one. . . .
                      note. . . this cartoon does not necessarily reflect the views of the this website, its management, or even the guy that drew it. . . .it was just too irresistable.
                      • plot-parisP
                        plot-paris
                        beautyful sketch, David!
                        I like the political criticism πŸ˜„
                        • P
                          pav_3j
                          David_H : exceptionally funny!
                          Modelhead : exceptionally concise!
                          pav
                            remus
                            To all the non believers, i will attempt to demonstrate why you are wrong.
                            Imagine a rocket flying parallel to the ground. Now imagine it has some wheels attached, everything's good so far. Now imagine the wheels happened to be touching a conveyor belt moving in the opposite direction to the rocket, the rocket will still be moving forwards and the wheels spinning but at a speed greater than that of the rocket.
                            Make any sense?
                            • Alan FraserA
                              Alan Fraser
                              Jakob,
                              Yes it would move backwards if it's engines weren't running, but the point is that as soon as they are...and it overcomes a slight amount of inertia in the wheel bearings...then whatever the conveyor is doing has no relevance at all to the plane. It will move forwards through the air at pretty much normal speed...however fast the conveyor is moving....and eventually take off.
                              The problem with the question is that it presupposes that the plane would be able to be kept at a single point in space with its throttle wide open, simply by the conveyor moving backwards matching its speed. This simply isn't true; the wheels effectively freewheel, so the motion of the runway is irrelevant. The thrust of the engines would not just compensate for the backward motion of the ground; the plane would HAVE to move forward....and it doesn't matter that the conveyor increases its speed accordingly
                              You have to kind of imagine the plane being suspended by a wire. The only real mechanical interaction it has with the conveyor is the relatively small amount of drag in the wheels. Once the forward thrust is sufficient to make that drag relatively insignificant, it will simply take off as normal with its wheels spinning madly. The plane is not clawing itself forward aginst the conveyor; it's clawing its way forwards through the air, which is not affected by the conveyor. In other words it's motive power is not connected to the conveyor at all...hence the analogy of the winch.
                              Once it is accelerating it only has to overcome the relatively tiny amount of friction in the wheels. This friction is largely unaffected by how fast the conveyor is travelling, which is why I said in my original post that the conveyor could be travelling at light speed...it makes no difference.
                              Modelhead...absolutely right...in reverse.
                              3D Figures
                              • Chris FullmerC
                                Alan, I see it better now after that last explanation of yours. Its not about the lift. Planes don't need lift to start moving forward. And once they are moving forward, their ability to gain more speed has nothing to do with the speed at which their wheels are turning, since the wheels just spin freely. The belt can keep speeding up, but the wheels just spin faster, but they don't hinder the forward movement of the plane.
                                • plot-parisP
                                  plot-paris
                                  ok. we agree with the fact that the plane, if it's engines are turned off and the conveyor is moving, will be transported backwards, right?
                                  so if the plane accelerates and tries to move forward, the conveyor accelerates likewise. wo we have a forward-motion of the plane and a backward-motion of the conveyor, which results in the plane being stationary compared to the people standing arround the whole machinery.
                                  this is exactly like pav running on his treadmill. no matter how fast he runs, the treadmill is always keeping him in the same place.
                                  we know the plane can only be lifted up by air pressing aginst it's wing (because that is how planes fly).
                                  we also know, that the plane stays stationary in relation to the spectators around (otherwise the conveyor would have failed it's purpose and the whole experiment would have gone wrong).
                                  and because the air arround the spectators is stationary (unless there is a fierce wind due to weather), it does not move in respect to the plane (except the air, that is sucked in and blown out by the jet enginge of course. but that does not pass by the wings of the plane).
                                  regarding these facts we have prove that there is no upwards thrust of the plane's wings by air.
                                  and that means, that the plane is not able to fly
                                  • Chris FullmerC
                                    The conveyor does not push backwards against the plane, only the wheels which can spin freely. So the conveyor does not inhibit the planes forward progress as it would a car.
                                    • david_hD
                                      david_h
                                      so if we apply this to cars. . .what does that do for the price at the pump?
                                        remus
                                        It gets expensive insert a plane maetaphor/similie/pun
                                          remus
                                          Ive got a variation on this conundrum, if anyones interested...
                                          Its a bit trickier than this one πŸ˜„
                                          • Chris FullmerC
                                            oh, ok another thought. Its not at all like a treadmill in that sense. Think of it as being on treadmill on a skateboard. If you use your legs to push against the treadmill to move at the same speed as the treadmill, then you stills stay stationary. A plane however is not using the wheels to accelerate. It is using something not connected to the ground - the air. So its more like standing on the sakteboard and pulling forward with your arms. No matter how fast the conveyor moves below your board, and how fast your wheels turn, it is the speed at which your arms can pull that move you forward. One arm pull distance is the same whether the conveyor is running or not. The same as the plane pulling itself forward through the air.
                                            Maybe thats a better analogy?
                                            • 2 / 6
