    How to rotate something...
    19 Posts 5 Posters 2.6k Views 5 Watching
      Maverick83
      @ Gaieus
      Thanks a lot man!! I've read your hints and i've successfully done what i was struggling to achieve! ๐Ÿ‘
      Bye bye - ciao
        Maverick83
        @ Pilou
        This is a good question... I'm also interested in this thing... Which program should I use to rotate my components in a realistic way for a movie presentation of the power plant?
        Btw when I opened this thread I was focusing on simple drawings movements, but you have started an interesting topic ๐Ÿ‘
        Bye bye - ciao
        • GaieusG
          Well, if you want to export an animation in the traditional way (File > Export > Animation), neither Sketchy Physics, nor Proper Animation would work because they cannot be exported (you can grab the animation with a screen capture device however - at the resolution your screen displays) - just as Pilou beat me in it above.
          Other than this, the only "traditional" way would be to make copies of the rotated components on different layers and make them visible%invisible on different scenes. Depending on the smoothness and length of the animation, this could require quite a lot of layers%scenes but would have the advantage that you could also animate the sun movement (which would also be essential in this moel I suppose).
            ๐Ÿ˜„ Ok so that was just for the drawing ๐Ÿ˜’
            For animation Sketchyphysics can make the trick!
            It's a very versatile plug for anything! ๐Ÿ˜Ž
            You can put any sort of Joints (rotate, motor etc)on any blocks, groups, nodes of elements etc...
            Load this file for example ๐Ÿ˜’
            The only default (till now) is that you can't use in the same time the "Animation Scene" of SU
            But as you can move normally all the SU screen with the mouse(+wheel, zoom rotate etc...) you can record the screen with prog like Camstasia ๐Ÿ˜‰
            But of course a little training is necessary ๐Ÿ˜‰
            Of course look the section Sketchyphysics ๐Ÿ˜„
              An another solution will be rendering the traditional Su animation (as said by Gaieus) in Kerkythea ;
              So you will have a very nice video (but surely very consuming machine time rendering) ๐Ÿ˜’
                Maverick83
                @Pilou
                Is that possible? ๐Ÿ˜ฎ
                • GaieusG
                  Yes, with SU2KT you can export your scenes as cameras (and sun settings also) and export a series of images you can compile into an animation later.
                  It won't save your time to set up the layers and scenes just like in a SU animation however (plus of course, render time will be longer).
                    Maverick83
                    Where can i find some information about SU animations?
                    • GaieusG
                      This is what the SU Guide tells about it: http://download.sketchup.com/OnlineDoc/gsu6_win/Content/K-Input_and_Output/Presentations/IO-ScenesAndAnimations.htm and here are some tutorials from SCF: http://www.sketchucation.com/forums/scf/viewtopic.php?p=52655#p52655
                        That is sufficent as "documentation" but you will see that is a nightmare to make with a big project! ๐Ÿ˜’
                        • GaieusG
                          That's true ๐Ÿ˜„
                            Else I remember of something! ๐Ÿ˜„
                            That can works for you!
                            Normally that is free! ๐Ÿ˜’
                            That should be suffisent for shematic animations!
                            You can make research on the forum with "antics" in the search engine box
                            I don't know if someone use it here?
                            • Alan FraserA
                              Alan Fraser
                              Antics will probably do the job. As for animating within SU itself, I have posted some ideas in the tutorials section, utilising workarounds with layers and Face Me components.
                              Such methods are probably nearing their sell-by date.
                              3D Figures
