    Animated growing cylinders :How to do ?
    13 Posts 7 Posters 2.3k Views 7 Watching
      remus
      So he does.
      I still reckon you could do it pretty easily with section planes, but in this case it looks like it was done by playing around with camera angles and switching between parallel projection and perspective modes. I could well be wrong though, i'll be intrested to hear how the man himself did it...
      • MALAISEM
        MALAISE
        Hello Remus
        I guess I've discovered the trick. I 've followed yours advices. Secret is lying
        in the animation's settings (scenes transition and scene delay are around 5 s) quite enough low to be seen in progress inside the selected scene
        • in the way you manage scenes properties.
        • the third remark concerns the activation of the toggle section off and on sub tool in section tool.
        Here is an example ( very basic one ! , according to your hints )
        I don't care about top and/or bottom whereas groups have been defined...
        Thanks you for yours friendly posts 👍 👍
        MALAISE 😄
        sorry for that strange written English (Anyway it's always a good exercice !) 😉
        basic animated growing cylinder
        • ely862meE
          ely862me
          hold on a sec. how u make the sections to move?¿
          this is amazing 😄
          i found something here: active cut 😛
          Elisei (sketchupper)
          Come and See EliseiDesign
          • DavidBoulderD
            DavidBoulder
            Here is link to more complex example of mine from another post. Building columns and skin grow separately.
            http://www.sketchucation.com/forums/scf/download/file.php?id=10591
            http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=10423
            David Goldwasser
            OpenStudio Developer
            National Renewable Energy Laboratory
            • Alan FraserA
              Alan Fraser
              This is a very well-known technique. You need two section planes...one at each end of the object you want to "grow"...only one of which can be active at any given time. By using two scenes and having a different section plane active in each scene, you will get the effect that you see. You can limit individual section animations by confining them inside a group. Then you can choreograph which section animations plays at any one time (or simultaneously) by arranging a more complex series of scenes.
              The model posted with the cylinders is a very nice example of multiple section animations.
              3D Figures
                You have a cool video about that here 😉
                • MALAISEM
                  MALAISE
                  Thanks Friends for all theses infos.. 👍 👍
                  MALAISE
                  • Alan FraserA
                    Alan Fraser
                    It's also worth remembering that section animations do not need to travel in straight lines.
                    section.skp
                    3D Figures
                    • GaieusG
                      Here is a tut on section plane animations:
                      By Martin: http://www.sketchucation.com/forums/scf/viewtopic.php?f=19&t=633
                      and a "joke" by him in the same thread: http://www.sketchucation.com/forums/scf/viewtopic.php?p=29295#p29295
                      • DavidBoulderD
                        DavidBoulder
                        Another interesting section animation I did showed 2nd floor of my house in perspective. Then I started moving the camera down and at the same rate moved the section plane down (from scene to scene). The end result looks like the section plane is stationary and someone is pushing the model up into the section plane where it dissolves.
                        Ends up being pretty cool effect.
                        David Goldwasser
