    [Plugin] Soft 2 face-edges / Unsoft edges
    9 Posts 5 Posters 13.4k Views 5 Watching
      Matt666
      Hi all ! Sorry for my poor english 😳 !!
      Here is a script can soft/smooth (like ctrl+erase tool) 2-face-edges of a selection.
      And another show all soften edges of a selection.
      They both work on all entities in the drawing if nothing's selected.
      I don't know if a similar script exists... ??
      All improvements or suggestions are welcome !
      EDIT: Now this tool is used in plugin Soften/Unsoften.
      Menu plugins : "soft 2 face edges" and "Unsoft edges"
      Frenglish at its best !
      My scripts
      • jujuJ Offline
        juju
        Hi Matt, please explain how this is different from the functionality we already have.
          Matt666
          Hi Juju.
          The procedure is different. I'll try to explain with the example above I've made. This script softened and smooth (like Ctrl + eraser) all edges with at least 2 sides connected. Thus, when we created a curved surface, this plugin softened and smooth all the edges except outer edges. Like the example.
          With native functionality (ctrl+eraser), you have to click on all edges to smooth and soften... I decided to make this plugin due to another, SSB. It created curved surfaces without smoothing or softening.
          Is it more clear now? πŸ˜„ πŸ˜„ πŸ˜„
          And sorry for all the faults πŸ˜•
          My scripts
            Baker518
            If I understand what you are saying, the ruby softens all surfaces leaving the edges hard. If that is correct, then you can still have points along the way to attach and work to or from. If memory serves me, I can remember softening/smoothing an object only to loose any distinguishable point to work from. Help me understand if I have missed it
            Mike
            Don't worry about things you have no control over. Worry is a lack of Faith!
            • jujuJ Offline
              juju
              @matt666 said:
              Hi Juju.
              O I C. Thanks for the explanation.
              • jujuJ Offline
                juju
                You mean by using the soften slider? Think so hey...
                  rv1974
                  Doesn't the Soften Edges panel already do this? Or am I missing something?
                  It appears Mat6666 is missing Soften Edges panel 😐
                    RickW
                    I think most SU ruby authors at one point or another end up writing something that duplicates an internal function, either from forgetting (or not knowing) it's native, or from trying to remove a step or two in the workflow process (with varying degrees of success).
                    We all have our moments...
                    RickW
                    www.smustard.com
                      Matt666
                      Soften Edges panel
                      😳 😳 Yes, I've forgotten it...
                      πŸ˜„ πŸ˜„
                      I look forward to the holidays!
                      My scripts
