    Linework Suffers with Styles
    2 Posts 2 Posters 604 Views 2 Watching
      msm
      Hello all,
      I am having a problem with my model when I apply a style to it. It seems to only happen with components I use. In the images below, you'll see what the trees are supposed to look like and then what they look like after I apply the style "Sketchy Edges Marker". Is there a way to calibrate the style so that the line work doesn't disappear?
      http://i36.tinypic.com/28qpee.jpg
      http://i33.tinypic.com/b99ezs.jpg
        Ross Macintosh
        What's happening is there are some really small edges defining the edges of those particular trees. The style is dropping all lines under a certain length. That is more a feature of how Styles work rather than a problem. You can have some control over what threshold is used by the Style. If you edit the Style (Edit tab in the Style panel) you can make adjustments in the Edge settings. Note there is a 'level of detail' slider that can be adjusted. Also note the 'Halo' setting that can played with to alter some effects. Make your changes looking at the model so you can see what impact various settings have.
        Regards, Ross
