    Flipping
    4 Posts 4 Posters 662 Views 4 Watching
      ShipAddict
      Hi Again πŸ˜„
      I'm afraid i'm having another little problem for a model i'm making.
      Let's say I have a cube. I put 3D text onto it saying "hello"
      I paste it to the other side, but it is the wrong way round. Hopefully the image will make it clearer what I am trying to do. I need some way of flipping it so it "turns" I have tried flip along axis but no joy.
      Thanks,
      SA
        remus
        You could use the scale tool, holding the ctrl key to make it scale around the centre point.
        • GaieusG
          Hi SA, It may be important that which axis you are flipping it along. Try all axes (I guess the red would work with the default 3D text)
          • Jean LemireJ
            Jean Lemire
            Hi Shipaddict, hi folks.
            Normally, 3D text comes in as a component. This component will assume a normal position on whatever flat surface.
            However, if you are not sure or you have exploded the text, see attached SU file for ideas.
            Rotating 3D text.skp
