Autocad to Sketchup
Hi iam somewhat new to sketchup and i need some help push pulling lines. iam not sure what iam doing wrong i try to select the lines i want to push pull but it has circle with a slash (cant do it) and i did do the make faces ruby app there was only 1 line that was not connected any help thanks much
Have you tried http://www.go-2-school.com or Aiden Chopra's youtube videos? They are excellent starting points for newbies.
You may also want to ditch the autocad linework until you are more familar with sketchup. Sometimes imported linework can be something of a bear to deal with if it isn't 'formatted' correctly.
well sorry, they are not lines but they are walls. I did a floor plan in autocad and then switched it over to sketchup to do an axonometric from the floor plan and pull walls desks chairs and such up.
any other info. thanks much again
Take a look in our Tutorials Forum at this Topic created by Kris. There is also a part 2.
This should help with some of what you are trying to achieve.
Creating walls from linework
