Components missing when rotated by other user
Can anybody help me out. I created a sketchup model and saved it onto our network. When somebody else opens the file and uses the model and rotates or pan, all of the components and materials disappear until the function is stopped and it regenerates. We need to fix this problem for some upcoming presentations. If anybody can help me out that would be great.
Cheng,
It sounds like some hardware problem. Try to play with (check/uncheck) the options at Window (menu) > Preferences > OpenGL.
If unchecking hardware acceleration seems to fix the problem, maybe an update of the video driver would help.
I tried changing the boxes but sketchup freezes up. Does it matter if you are the administrator of the computer?
I too think this is purely a hardware issue. I think the other comps are not strong enough to handle the model as well as your computer so they are dumbing it down while they rotate and pan. A way around this is to turn off all uneeded components while rotating and turn them back on once you get in set in place. I ususally use scenes to manage my components and styles.
