    SketchUpBBS-Subdivide&Smooth piugins test
    27 Posts 9 Posters 3.6k Views 9 Watching
    • soloS Offline
      Well I decided to just sub half of it and it worked well actually.
      Damn good modeling!!
      http://img70.imageshack.us/img70/4678/32082788ja4.jpg
      Now I am really curious as to how it was modeled.
      • RichardR Offline
        Richard
        Looks like maybe poly reduced then smoothed back out! Yes I would like to know how to model nude women!!!! Then 3D print them in bits and make myself an army! ๐Ÿ˜
        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
          kwistenbiebel
          Yeah...Richard is being his good old self. ๐Ÿ˜„
          We should have live nude modeling sessions like painters have. A webcam on the model etc...
          • RichardR Offline
            Richard
            I bags doing the filming and taking measurements!
              bianhai
              Head picture model tutorials
                bianhai
                Head picture model
                • soloS Offline
                  um, okay!
                  So let me try it too.
                  Attached is a .skp (very low poly) that if you explode it and apply 2 iriterations will produce a wonderfully smooth perfect face as shown in image below.
                  http://img112.imageshack.us/img112/5897/headtestqjg0.jpg
                  Solohead.skp
                    bianhai
                    GOOD!solo!
                    • soloS Offline
                      Thanks but I have to be honest and say it's reverse engineered, it is in fact a Poser head that I reduced then imported into SU and used the sub-smooth tool to recreate the mesh.
                      I wanted to reduce further and make a series of in progress screen grabs but decided against it.
                        bianhai
                        Uses this plug-in
                        http://www.smustard.com/script/subdivideandsmooth
                        usage Installation
                        Unzip the file you downloaded.
                        You should now have a file named 'subsmooth_loader.rb' and a folder named 'Subsmooth'.
                        Copy both the file and folder to your SketchUp/Plugins directory.
                        Close SketchUp if you have it open.
                        Run SketchUp
                        If you do not see the Subdivide and Smooth toolbar, go to Window->Preferences->Extensions and make sure that 'Subdivide and Smooth' is checked.
                        A new menu item will be created under your 'Tools' menu and you will see a new toolbar.
                        Known Issues
                        Bug splats can occur when using other plugins such as SketchyFFD, JointPushPull, Offset On Surface, etc. while editing a subdivision proxy. It is recommended to only use the standard SketchUp tools (and the tools included with this plugin) while editing a subdivision proxy.
                        Bug splats can occur while using the 'Extrude' tool when multiple faces are selected on a proxy.
                        Bug splats can occur when using the 'Knife Tool'
                        Using the 'Subdivide Selection' tool may cause bugsplats or SketchUp to hang in rare situations.
                        If you 'Undo' an operation while editing a subdivision proxy, you will not be able to use the 'Redo' command.
                        If you cut and paste a proxy, it will no longer behave as a proxy. You must select it and then click the 'Subdivide and Smooth' icon to re-create the proxy.
                        • plot-parisP Offline
                          plot-paris
                          thanks a lot, bianhai.
                          I think most of us are already messing arround with Subdivide&Smooth.
                          but your modeling-tutorial looks really inspiring! has something of a sculptor.
                          I definitely have to try this sometime!
                            batas senja
                            wow....it so wonderful... ๐Ÿ‘
                              You can use the free "Make Human" and make any anatomy and then introduce it in SU ๐Ÿ˜‰
                                kwistenbiebel
                                I still can't understand why someone would want to present alien mesh as Sketchup geometry...
                                  Maybe for full compatibilty?
                                    plot-paris
                                    I think kwistenbiebel meant that it doesn't make sense, if someone imports a mesh and then tells everyone he has created it in SketchUp... ๐Ÿ˜‰
                                      bianhai
                                      Solohead render
                                      • H Offline
                                        hugoyu
                                        ๅฎคๅ†…่ฎพ่ฎกๅธˆ :Nice to see you here.You did a wonderful job. ๐Ÿ‘
                                        • urgenU Offline
                                          urgen
                                          ...thanks ,Bianhai and Solo!good topic ๐Ÿ‘
                                          --pupil forever...------
