    SketchUpBBS-Subdivide&Smooth piugins test
    27 Posts 9 Posters 3.6k Views 9 Watching
      bianhai
      GOOD!solo!
      • soloS Offline
        Thanks but I have to be honest and say it's reverse engineered, it is in fact a Poser head that I reduced then imported into SU and used the sub-smooth tool to recreate the mesh.
        I wanted to reduce further and make a series of in progress screen grabs but decided against it.
          bianhai
          Uses this plug-in
          http://www.smustard.com/script/subdivideandsmooth
          usage Installation
          Unzip the file you downloaded.
          You should now have a file named 'subsmooth_loader.rb' and a folder named 'Subsmooth'.
          Copy both the file and folder to your SketchUp/Plugins directory.
          Close SketchUp if you have it open.
          Run SketchUp
          If you do not see the Subdivide and Smooth toolbar, go to Window->Preferences->Extensions and make sure that 'Subdivide and Smooth' is checked.
          A new menu item will be created under your 'Tools' menu and you will see a new toolbar.
          Known Issues
          Bug splats can occur when using other plugins such as SketchyFFD, JointPushPull, Offset On Surface, etc. while editing a subdivision proxy. It is recommended to only use the standard SketchUp tools (and the tools included with this plugin) while editing a subdivision proxy.
          Bug splats can occur while using the 'Extrude' tool when multiple faces are selected on a proxy.
          Bug splats can occur when using the 'Knife Tool'
          Using the 'Subdivide Selection' tool may cause bugsplats or SketchUp to hang in rare situations.
          If you 'Undo' an operation while editing a subdivision proxy, you will not be able to use the 'Redo' command.
          If you cut and paste a proxy, it will no longer behave as a proxy. You must select it and then click the 'Subdivide and Smooth' icon to re-create the proxy.
          • plot-parisP Offline
            plot-paris
            thanks a lot, bianhai.
            I think most of us are already messing arround with Subdivide&Smooth.
            but your modeling-tutorial looks really inspiring! has something of a sculptor.
            I definitely have to try this sometime!
              batas senja
              wow....it so wonderful... 👍
                You can use the free "Make Human" and make any anatomy and then introduce it in SU 😉
                  kwistenbiebel
                  I still can't understand why someone would want to present alien mesh as Sketchup geometry...
                    Maybe for full compatibilty?
                      plot-paris
                      I think kwistenbiebel meant that it doesn't make sense, if someone imports a mesh and then tells everyone he has created it in SketchUp... 😉
                        bianhai
                        Solohead render
                        • H Offline
                          hugoyu
                          室内设计师 :Nice to see you here.You did a wonderful job. 👍
                          • urgenU Offline
                            urgen
                            ...thanks ,Bianhai and Solo!good topic 👍
                            --pupil forever...------
                            • 2 / 2
