    Admin Bldg in Brasilia (Podium render)
    11 Posts 7 Posters 671 Views 7 Watching
    • EdsonE Offline
      Edson
      exterior view of a project i posted here in january, done in podium with some postprocessing. doubtless, there is much room for improvement but, what the heck, it feels good to be able to show some progress.
      http://www.mahfuz.arq.br
      • soloS Offline
        looking fantastic Edson.
        • Mike LuceyM Offline
          Mike Lucey
          Nice composition Edson and I particularly like the
          transparent trees and people, they don't dominate
          the scene. The only comment I would make is that
          I would like to see a little texture in the steps,
          one that fades off if possible?
          Mike
          • boofredlayB Offline
            boofredlay
            Very nice.
            What is the blue against the building?
              kwistenbiebel
              Edson owns Podium. πŸ˜„
              You're a great example of someone biting himself in a piece of software until he gets it on its knees. Your progress is remarkable.
              Great stuff!
              • EdsonE Offline
                Edson
                pete, mike, eric and biebel,
                thanks for your kind words of encouragement. they nourish me to keep on working to reach a higher level of expertise.
                apart from any professional consequences it is really a pleasure to do renders like this. i must confess to having great fun at it.
                eric, the blue at the bottom is a waterfall. check the earler post mentioned above to see a full view of it. that scene is one of the ones i intend to render soon.
                mike, i will do some work on it to add more texture and shadows on the trees and people.
                • FrederikF Offline
                  Frederik
                  Looks nice, Edson..!! πŸ‘
                  How long time did it take to make this render..??
                  I can see that you've spend some time doing some post pro... πŸ˜‰
                  Cheers
                  Kim Frederik
                  • EdsonE Offline
                    Edson
                    hi kim,
                    this one cooked for about 5hs using the noisy_600 passes preset. i had achieved basically the same quality in 20+min with another preset but since the facade is protected with horizontal louvers (small aluminum tubes placed close together) the render showed the dreaded 'moire effect'. i tried replacing the actual tubes with an image of them. it did not work well as the render is not showing them. perhaps going back to the tubes and leaving it cook longer will get rid of that effect.
                    yes i did some post processing (about 20min worth of it): sky, trees and people were inserted in pp.
                    • FrederikF Offline
                      Frederik
                      Sorry for my nob question, but doesn't Podium support spherical skies..?? πŸ˜•
                      I thought it would possible so that you wouldn't need to apply it in post pro...
                      Any way... The time spend on this nice render isn't too bad... πŸ˜‰
                      Darren (aka Sintra) have posted some links to some nice skies at the KT Forum, maybe you and others can use these as well..?! πŸ˜‰
                      (flickr.com)
                      (flickr.com)
                      (flickr.com)
                      Reply from Edson:
                      not as far as i know. the alternative to post processing is to paste a sky image over a large face, which i did in the render i posted earlier.
                      and thanks for the links.
                      Cheers
                      Kim Frederik
                        tomsdesk
                        Edson, you have come a long way in a short time: good work, excellant image!
                        2.5D Trees & Shrubs!
                        • EdsonE Offline
                          Edson
                          thanks, tom.
