πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Various problems - driver related?
11 Posts 4 Posters 767 Views 4 Watching
    Guru
    Please help.
    I'm having all kind of weird problems with sketchup pro 6 (demo version).
    Besides having strange graphic anomalies, I can't edit, push / pull, draw, pick surfaces, etc.. in perspective mode, but if I change to parallel projection view, everythings OK. My graphics card is an ATI 9600 xt 256 mg and I already tried diferent catalyst drivers, from 8.3 onward, and the problem remains. I even unchecked fast feedback from preferences, disabled mipmapping, catalyst A.I., anti-aliasing, but the problem remains. The only thing that aparentely resolves it, is if I uncheck hardware acceleration in sketchup preferences, but that way is unbearble slow to work with, and the stranger thing is that, as I said, with "everything on", the problems only occur in perspective mode.
    Help
    Guru
    PS A colleague of mine also has the same graphics card, but working with old drivers, and no problem there.
      dylan
      Well it certainly sounds like a graphics card problem.
      You could try to locate the driver version your friend is using, or try out the Omega drivers for ATI.
      http://dmdarchitecture.co.uk/
        juju
        Back when I was using SU6Pro on my old machine with an ATi 9800 Pro 128MB I used the Omega Drivers and it worked great. Try them, have a look at the optimisation guide for the BIOS as well.
          Guru
          Thanks for all your help
          I tried an older catalyst model (8.1) but still no go.
          I also tried the latest omega drivers, based in the catalyst driver 7.12, but after installment, I couldn't launch Ati control panel (click it but doesn't start!), only Ati tray tools work, and inside sketchup, the option hardware acceleration was grayed out, wich, I assume, means sketchup didn't recognize hardware acceleration capabilities with that driver.
          perhaps it means the installation was corrupted.
          Has this ever happened to anyone, the Ati control panel, I mean..
          Thx in advance
          PS. Juju, what Bios optimization guide are you refering to?
            sketch3d.de
            as always, a clean driver installation requires to uninstall the existent driver first (w/ admin. rights), restart the operating system, install the new driver (w/ admin. rigths) and restart OS again...
            ... but as a guru you surely know this already πŸ˜„
            btw, it's in general a good idea to mention the platform/operating system used... at least w/ hardware/driver related problems.
            Norbert
              Guru
              Norbert
              Thought I mentioned it, but you're right..
              The OS is WinXP Pro SP3, the card is a Sapphire 9600 XT 256 mg AGP, no problems before, with sketchup 5 on any driver.
              I did follow the book regarding uninstallation of previous drivers:
              • administrator
              • uninstall driver
              • reboot
              • clean garbage left behind
              • reboot
              • run in safe mode
              • use driver cleaner: clean ATI leftovers; - clean driver.cab, SP3.cab
              • reboot
              • scan registry with Advanced System Optimizer: clean anything from registry related to Ati
              • install new driver
              • reboot.
              I do that procedure before any driver installation. I even create a restore point and backup the system state before such operations. So I don't think that's the problem.
              thx anyway
              PS the Guru term comes from a long way back..., there's so much more to life.. πŸ˜‰
                sketch3d.de
                @guru said:
                loooong list snipped
                okie, sounds safe 😎
                if an older ATI driver version doesn't help, you mabye should get rid of the ATI card and switch to an e.g. nVidia GeForce 7900 GS/GTX (starting by approx. 100.- U$) which is probably the fastest (from nVidia) you can get for the AGP slot...
                ... or drop the whole system, which is obviously not a recent one, and invest the money in something more current as e.g. an Intel Core Duo w/ a nVidia 88xx series (PCIe).
                Norbert
                  Guru
                  That's what I intend to do, but I want to maintain my present system as a working station as it's more than capable for CAD and 3d visualisation operations, and is essencial in scene rendering phases (half the final rendering's total time πŸ˜‰.
                  I'll probably buy for this system the fastest / best AGP card I can get!
                    sketch3d.de
                    which is (under Windows) a nVidia Quadro FX (or GeForce) only. Don't buy ATI Radeon, dunno the FireGL stuff of them.
                    Norbert
                      juju
                      There was a BIOS optimisation guide that helped improve performance of the Omega drivers, I can't find it on the site any more, so I'm guessing it's not necessary any more.
                        Guru
                        I'm going to run an openGL viewer I ran into today, to see if the drivers have specific problems with open GL 1.5.
                        I'll let you know how it goes, later on..
                        Regards
                        Guru
