    Google Earth/Maps vs. Microsoft Virtual Earth
    16 Posts 10 Posters 1.1k Views 10 Watching
      perk
      I also use Maps.live.com
      • FrederikF Offline
        Frederik
        I'd say that I use both app. 50/50...
        For me it all depends on the project and need... 😉
        Cheers
        Kim Frederik
          dylan
          I use both, but I find the images much better from Microsoft live.maps
          http://dmdarchitecture.co.uk/
            kwistenbiebel
            I shouldn't be saying this out loud, but wouldn't it be possible to have a Live.maps plugin in Sketchup?
            Or is that blasphemy?
            • V Offline
              Voder Vocoder
              So you chaps haven't noticed that the images are much older in Virtual Earth?
              ~Voder
                kwistenbiebel
                No.
                For most architectural use, this should not be a real hassle I think.(unless the images would be over 10 years old, which I don't expect)
                To use as a ground texture to start mass modeling, resolution and image quality is the key.
                The down side to maps.live is the availability of maps (less areas scanned than GE).
                So using both GE as live maps seems to be the way to go as most people replied.
                A live.maps plugin in Sketchup would be a nice addition.
                Best of both worlds!
                  Well, my place is not only rather bad on liev.maps but even the streets are not always where they are shown and the names are totally screwed up. It shows streets where there are squares etc.
                    twharvey
                    Have you guys seen the new API to incorporate GE into web sites. This is pretty cool. And it seems to load faster than the standalone GE.
                    http://code.google.com/apis/earth/
                    And here's an example I'm working on.
                    http://www.twharvey.talktalk.net/index.htm
                    Tom
                    Tom
                      Too bad I have Firefox 3 and it is not supported (yet).
                      • cerevellumC Offline
                        cerevellum
                        @Gaieus: Re: FF3 >> It is now! (gearthblog.com)
                        @Tom: Nice site so far, but for some reason I couldn't get the Earth option to work. It keeps telling me there is a problem with the plugin. gl!
                        Zach
                          lewiswadsworth
                          Zach
                          Seems to work fine for me, with a bit more snappiness than the stand-alone GE, as Tom noted.
                          col sporcar si trova
                            cerevellum
                            Hmm, weird..
                            It couldn't have to do with Firefox 3, do you think? Anyone else having this issue?
                            Lates,
                            Zach
                              lewiswadsworth
                              @cerevellum said:
                              Hmm, weird..
                              Lates,
                              Zach
                              I'm using Firefox 3...however, I did notice something odd about Firefox, with the browser consuming 98% of my CPU after I installed the plugin, and not releasing it (and still showing in Processes) even after I quit it. I'll need to check and make sure that was just the GE plugin and not something else, like a buggy theme, of course.
                                Thanks for the info, Zach! I installed the plugin and Tom's place streams just fine on FF3. I could also navigate to my place and see it just like in the standalone GE app (had no problems with any issue).
                                This is my office however with some dedicated broadband connection. I1ll test it at home as well with my own broadband.
