    [Plugin] Face Flattener 0.19
    50 Posts 29 Posters 56.7k Views 29 Watching
      dylan
      Thanks Zack.
      This could prove really useful for the bad AutoCad imports I sometimes get.
      http://dmdarchitecture.co.uk/
        matteo
        Thank you. This may become one of the most used scripts in my daily work.
        hire me: http://www.nonsolo3d.it/ !
          kwistenbiebel
          I love the idea!
          Can it also remove the unneeded edges afterwards , so we have clean geometry to push pull?
          • cerevellumC Offline
            cerevellum
            No problem, glad it could be useful to some!
            So, in fact there is more functionality to this script, but a lot of the methods are not being used currently. I need to get it up to speed, maybe over the weekend. Basically, if you intersect with model you can erase the inside edges, and I'm working on getting them to remove automatically. The methods are all in the script, they just need to be called, and in the right order (what I have been struggling with).
            Anyway, feel free to play around with the script. I'll do my best to update it, too.
            Thanks again,
            Zach
            • Mike LuceyM Offline
              Mike Lucey
              Thanks Zach,
              This looks like the Ruby that we talked about at the
              Hotel Avante, very useful indeed.
              Be sure to get your Avatar up there soon and don't be
              a stranger 😄
              Best,
              Mike
              • RayOchoaR Offline
                RayOchoa
                Dang, Sketchup is starting to look more and more like CAD programs like Wings3d and Rhino. he he its going to end up as complicated too. All it needs now is faster control over high poly models
                CaR DeSiGnS bY mE
                http://ray-ochoa.com
                  rv1974
                  @Rayochoa:
                  This is a PLUG-IN. If you don't need it simply don't plug it.
                  IMHO it has a good potential. And if this tool will help me to save a couple of hours per year so why not?
                    cyan.archnet
                    thanks a lot for the plug-in, sure a big help!!
                      Jackson
                      Zach- thanks for this ingenius ruby, can't wait to give it a try!
                      Jackson
                      • plot-parisP Offline
                        plot-paris
                        nice tool. I am definittely in danger of flattening every model I can lay my hands on (my colleagues won't like that 😉 ).
                        I am looking forward to the "auto-cleanup" version.
                        cheers,
                        Jakob
                        • RayOchoaR Offline
                          RayOchoa
                          @rv1974 said:
                          @Rayochoa:
                          I didin't say i didn't like it i said that all these plugins are taking sketchup very far. But hey i like this better, rather than learning everything at the same time little by little is way better
                          CaR DeSiGnS bY mE
                          • RayOchoaR Offline
                            RayOchoa
                            U maybe wan't to take a look at this
                            cleanup.rb
                            CaR DeSiGnS bY mE
                            • MALAISEM Offline
                              MALAISE
                              😄 Thanks a lot
                               What a waste of time I got, trying to understand why theses blood... lines didn't made a surface.
                              friendly 😍 MALAISE
                              ( sorry for my approximative english )
                              • W Offline
                                watkins
                                Dear Ray,
                                I tried out your script on the following simple model.
                                Draw a rectangle, say 100 mm by 100 mm, and then pull it up 10 mm into a 3D shape.
                                Use the move tool to pull up one corner on the top face by 0.1 mm.
                                Draw a few lines on the sides to divide areas into two, and perhaps a few random, un-terminated lines on various surfaces.
                                Select all and run your script.
                                When I do this I lose the top face. Interestingly enough this also happens when I run the script cleanup_model.rb (by John H. Aughey). The script deletecoplanaredges.rb (by Jack Dolabany)removes all redundant co-planar lines, but leaves the top face with its centre fold untouched.
                                I imagine that this is not what you had in mind.
                                Kind regards,
                                Bob
                                  rcossoli
                                  thanks, will be very useful
                                  THREEDIMENSIONSWEB dot COM
                                    cerevellum
                                    Hi Ray and Bob,
                                    This is something I've noticed while working on my flattening script, and I still haven't figured out why it happens. The simplest way of reproducing this is to draw a box, add a rectangle to the top surface and connect it with a line to the outer edge loop. When erasing one of the edges of the rectangle that was added, both faces disappear.
                                    However, if you were to erase the edge that connects both edge loops first, then you can erase the edges of the inside rectangle just fine. It apparently has to do with the order in which you erase coplanar edges. Delete edges in the following order: edges connected to 0 faces go first, then edges connected to 1 face, and finally edges connected to 2 faces.
                                    See ya,
                                    Zach
                                    • W Offline
                                      watkins
                                      Dear Zach,
                                      The script deletecoplanaredges.rb failed your example too, so some recoding is needed to get a more reliable cleanup script.
                                      Regards,
                                      Bob
                                        @cerevellum said:
                                        Hi Ray and Bob,
                                        This is something I've noticed while working on my flattening script, and I still haven't figured out why it happens. The simplest way of reproducing this is to draw a box, add a rectangle to the top surface and connect it with a line to the outer edge loop. When erasing one of the edges of the rectangle that was added, both faces disappear...
                                        Ha! Beautiful! I love these "glitch hunts". And you cannot even heal the face by redrawing an edge of it until you get rid of the leftover geometry in the middle! 👍
                                        • W Offline
                                          watkins
                                          Dear Gaieus,
                                          Perhaps some of our script writers could come up with a more reliable clean-up script.
                                          I note from Zach's example that the line joining the inner and outer loops is bounded by the same area, while the lines forming the inner and outer loops are bounded by different areas. What makes an area/surface unique, and could this be used to decide on the order of line removal? At least deletecoplaredges.rb leaves the centre fold line in an non-coplanar surface alone, and so perhaps this would be the script to start with. A nice icon would not go amiss, say an image of a few random, crossed lines.
                                          Kind regards,
                                          Bob
                                            Bob, Zach,
                                            I have a script that creates a menu item "Remove unused edges" in the Edit menu (for the life I cannot locate the script anywhere to see the file name of it). Using the script it also deletes the top surface (so the order it deletes the lines must be wrong as well).
                                            I have noticed a couple of times that using it leads me to lose a coupleof faces (especially after complex, curved intersections).
                                            • 1 / 3
