    Lost ability contextual right click
    14 Posts 5 Posters 1.7k Views 5 Watching
    • soloS
      Happened to me on a few occassions, closing and re-opening normally sorts it out again.
      • L
        lapx
        Yeah, that's the first thing that I did. Then resorted to rebooting. Tested in several files. No luck so far. Maybe ruby script or hardware related? πŸ˜•
        Edit: I'm almost certain it's software related to su. I went back to an older version of su and it works fine. It must be ruby related.
        • L
          lapx
          Might anyone have a solution to this problem? The context won't remain highlighted after picking. Therefore I'm not able to perform operations after picking. Ruby god's help!!! 😒 😒 😒
          • L
            lapx
            Yep,
            It's definitley a ruby script. I dumped all my ruby's in a temp folder. reopened Su, worked fine. Now it's a matter of which one of 258 Ruby is the culprit? 😑
            • soloS
              Remove bezier curve and spiral staircase, they caused me to lose my right click before.
              • L
                lapx
                Thanks Solo, but those were not the problem. I put out a request for help on the Ruby forum.
                I almost 100% sure it's a recently downloaded ruby if I could only remember 😞
                • L
                  lapx
                  I think I found the problem. πŸ˜„ It was the projection rubies. Is this a known bug? The projection tools are great. I would hate to have to give up its functionality.
                  • T
                    todd burch
                    If the object won't remain highlighted after a right click context menu opens, it could be either a script using the Observer interface or just a "regular" (old-fashioned) script that validates / manipulates the selection in the context menu handler. In the situation you have described, this is a big error.
                    You can try to narrow down the possible culprits by searching your scripts to find out which ones modify the "selection" object (via selection.add, selection.clear and selection.remove) and that install a context menu handler (via UI.add_context_menu_handler). The easiest way to do the latter is to look in the context menu for non-standard options when a group is selected, and figure out which scripts add those options.)
                    Todd
                    • L
                      lapx
                      huh!
                      Thanks Todd,
                      Your talking over my head now.
                      Did you see my comments above? It was a result of the projection scripts. There were several rb's project_*.rb I remove from the plugin folder. Everything seem to work fine after this. I may have unzipped some things in the wrong folder. I will go back and explore.
                      I have version "projection_v6.zip". Is this the latest?
                      • L
                        lapx
                        The key to installing projection tools is to follow instructions 😳 😳 😳 .
                        Just incase someone else runs into this problem, read instruction carefully before unzipping rubies in folder. Instruction say to delete several other scripts before installing. This was the problem. Other scripts which should be erased were in conflict with projection tools.
                        • T
                          todd burch
                          OK, glad you got it figured out!!
                          Todd
                          • L
                            lewiswadsworth
                            Actually, I had the same thing happen, and I narrowed the cause down to a new version of VRay for SU's Ruby. Oddly enough, it would only happen on one of the two computers for which I bought the plugin.
                            col sporcar si trova
                            • K
                              kwistenbiebel
                              Indeed, VrayforSU (latest service release) seems to screw up the 'Subdivide 'nd Smooth' pugin as well on some PC's.
