    Lobby - WIP
    29 Posts 11 Posters 3.6k Views 11 Watching
      remus
      Looking good, altohugh i dont liek the design particularly ๐Ÿ˜›
      crits: the lights on the left door arent on, not sure if this is intentional though. And you might want to bevel some of those edges, its all looking very sharp at the moment.
      • marked001M Offline
        marked001
        like i said.. had nothing to do with the design...dont like it either..
        not sure what is up with those lights on the left..they're components.. should be acting the same as the other side.. fixing some of the tiling issues now..
        http://www.revision21vis.com
        instagram: revi21on
        • AnssiA Offline
          Anssi
          In general it is a good render. It is just that indirect light almost always looks bland, it is even meant to - light fixtures like this are generally used to provide a glare-free computing environment. I would use something more "dramatic" (meaning more direct light) to light a lobby. The lighting levels in the render might be even a bit too high, as the ceiling is quite washed out, or the ceiling material is unrealistically reflective.
          So this is more a critique of the design than of the image.
          Anssi
            marked001
            i can always count on Anssi to have some good insight.. ๐Ÿ˜„ totally agree too... oh well.
            here is an update.. no idea what the color looks like since both my monitors need to be calibrated and it looks totally different on both ๐Ÿ˜•
            http://img111.imageshack.us/img111/7620/300franklin061508nq2.jpg
            instagram: revi21on
              kwistenbiebel
              Much better. I'd make it a 2 point perspective though. Maybe try the shift lens in Maxwell?
                marked001
                hmmm.. good idea, let me see if i can figure that out.
                instagram: revi21on
                  marked001
                  here's what i ended up with... i couldnt get my head around Shift Lens...i think i know the concept, but for me, it was all trial and error and i wasnt getting where i needed to be... i tried to output a 2 point perspective from sketchup..but the view is totally changed in maxwell ๐Ÿ˜•
                  http://img210.imageshack.us/img210/3626/300franklinfinalti5.jpg
                  instagram: revi21on
                    Archi Rag
                    Looks awesome, i especially like the reflection of the person in yellow on the wall although its kinda weird with the column perspective, its good the way you have a less crowded (people group)and has been cool to seen a pro's process through images, nice one!
                      marked001
                      ha..pro....good one!
                      i did leave out a few other back and forth images with the client.. it didnt clear up quite as quickly as i would've liked..this took just about 24 hours to get this far ๐Ÿ˜• not sure what was slowing it down so much..
                      instagram: revi21on
                      • StinkieS Offline
                        Stinkie
                        Yeah ... shift lens. No idea how it works either. Sheik oughta do a tut on that one!
                        I'm surprised 2 point didn't work. Works for me. I generally go through the Studio - you? Maybe the plugin doesn't handle 2 point well or something. Wouldn't surprise me. ๐Ÿ˜„
                        Do you make your own mats? Or do you take the lazy boy route - download mxm, swap textures - like me?
                          These are nice Jason,
                          The shift lens intrigues me. I've wished for something like that--vertical "film" plane with lens raised to adjust view.
                            marked001
                            stinkie.. i usually do just use alot of the mxm's from the gallery out of laziness time constraints..but for this one, the stone was pretty specific.. so had to make my own.. my lazy way of doing that is downloading a similar material.. and using the settings, but changing the reflectance map, bump map, etc... mostly b/c i dont usually understand all of that other stuff ๐Ÿ˜„
                            yeah, when i exported the 2 point.. it totally changed my viewpoint.. havent been using studio b/c my components get rotated all wacky...hopefully this new plugin today addresses this..
                            hopefully, i'll get some time to mess with the shift lens on an upcoming project dave...or maybe biebel can since he's always playing around..then he can tell me how to do it ๐Ÿ˜‰ lol
                            instagram: revi21on
                            • StinkieS Offline
                              Stinkie
                              lol. Yeah, same approach here. Works pretty well, though.
                              Nasty bug, that one. Unworthy of such an expensive app. Unchecking "instances" in the export options usually helps (that is, unless you're running Mac OS). There's another (less RAM hungry) way too: explode components you rotated in SU, and make new components out of them. Hope NL gets this one sorted fast!
                              B?
                              Edit: 1.7 is out! New plugin too:
                              SketchUp plug-in for Maxwell Render 1.7
                              Improvements and fixes
                              โ€ข Proxy objects implemented. Proxy objects allow users to replace low polygonal versions of individual SketchUp components (which are used for easier work in SketchUp) by higher polygonal versions of the components when exporting to Maxwell Render.
                              โ€ข Camera parameters are now stored per SketchUp page. Previously there was just a single entry for all SketchUp pages.
                              โ€ข The plug-in UI has been adapted to integrate the new Physical Sky parameters.
                              โ€ข Shadow channel was added to the list of channels to export.
                              โ€ข Fix: wrong positioning of flipped objects in Maxwell Studio.
                              โ€ข Fix: crash when instancing components with no 3D geometry.
                                marked001
                                well..despite that last image being the 'final'... they came back with more changes.. despite seeing like 5 progress images.. and the things they want to change are the wood and the actual view..two things that have been the same all along! such a pain.. anywho, i figured out the shift lens...which is pretty cool.. i 'think' i'm still getting flipped components in studio though ๐Ÿ˜• i was so all over the place rushing to fix this... i dont even know.. really want to try out the proxies.. i'm using 1.7 now, but didnt even look at the improvements to the plugin..duh..
                                here is a 5 minute test.. cheffey is hooking me up and running the new 'final' for me on his network... i need my one and only pc to work all weekend ๐Ÿ˜•
                                http://img504.imageshack.us/img504/7893/lobby04ge1.jpg
                                instagram: revi21on
                                • StinkieS Offline
                                  Stinkie
                                  Much better already. Care to share your knowledge on the esoteric art of camera shifting?
                                  I did a few tests, and I'm not getting any flipped components anymore. So far. ๐Ÿ˜„ The new sky system is pretty impressive!
                                    marked001
                                    the lens shift was pretty trial and error.. i did it in studio, so not sure how it works in the plugin.. but you just throw in some numbers and it alters the perspective...reset the viewpoint and keep going until the lines are vertical.. something like that..haha..
                                    here is what i came up with.. this rendered for 18 hours and hit SL14..something was def messing up my last file.. 24 hours and it barely broke SL12 i think..
                                    http://img75.imageshack.us/img75/4296/300franklinlobbygu3.jpg
                                    instagram: revi21on
                                      kwistenbiebel
                                      The image is a bit CG, but nice.
                                      I didn't know Maxwells shift lens was that hard to control.
                                      In Vray you set a value for shift lens (0.1 or 0.2 does the trick most of the time) and it will correct the perspective, but it's also a trial and error to get it completely parallel.
                                      • chavinskeeC Offline
                                        chavinskee
                                        much easier workflow for me is to use transformation tool in photoshop and skew or distort the image til it appears "vertical". just my 2 cents worth ๐Ÿ˜‰
                                        http://chavinskee.blogspot.com/
                                          Durant Hapke
                                          Chavinkee blast oven,
                                          This is some Jack bird action wood... Like the wood looks very real...
                                          I would buff that action with some honey butter.
                                          Bring it, bring the mass.
                                          Durant "fire in the bucket" Hapke
                                            marked001
                                            awwww... fine.. haha..the people definitely dont help the realism..i need to invest in some high poly peoples..
                                            i might have exagerrated a bit.. its pretty much the same thing.. just that everytime you change the value, your viewpoint changes..
                                            instagram: revi21on
