    Surface Area function?
    7 Posts 5 Posters 15.3k Views 5 Watching
      ridix
      Is there a function to calculate surface area in SU? It’s nice to be able to calculate area for non rectangular room plan.
      • L
        lewiswadsworth
        Yes...select a face and right-click. Among the options in the context menu is "Area." There are further options for selected, layer, or materialfor limiting the area measurement.
        col sporcar si trova
          ridix
          Nice, thanks!
          • Jean LemireJ
            Jean Lemire
            Hi folks.
            When used on a surface, the Text Tool offer the area by default, using your base unit (square meters if you use meter and so on).
            Just ideas.
              ridix
              Ya I did know test the unit after it. I will play around with the units and see.
              • TaffGochT
                TaffGoch
                Also,...
                ...if you leave the 'Entity Info' box open while you work, you'll see that the area of selected face(s) is reported therein.
                "Information is not knowledge." -- Albert Einstein
                • W
                  watkins
                  Dear All,
                  You could also use Jim's most excellent 'query' tool. Like TaffGoch I use the Entity Info box all the time, using it to name/rename groups on the fly. Using the Entity Info box with the Outliner box is even better.
                  Regards,
                  Bob
