    [Obsolete] Tools On Surface - v1.2
    62 Posts 38 Posters 32.5k Views 38 Watching
    • jujuJ
      juju
      Thank you very much!
        apx
        Error Loading File EraserOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File LibOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File LineOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File OffsetOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File PolygonOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File PolylineOnSurface.rb
        No such file to load -- LibTraductor.rbError Loading File ZLoader__OnSurface.rb
        I get LibTraductor.rb from old version...
        Thanks Fredo6!
        • fredo6F
          Oops, I forgot to include LibTraductor.rb in the package, which indeed will be missing if you never installed previous verssions of ToolOnSurface or JointPushPull or BezierSpline
          I have updated the ZIP archive in the main post of this thread
          http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=10242&p=66968#p66968
          Thanks, apx, for advising on this problem
            a4chitect
            thanks santa fredo!!!
            your scripts are state of the art! but please take an occasional rest so as not to get fed up and quit 😄
            • H
              human
              AWESOME!!!!
              😍 😍 😍 😍 😍 😍 😍 FREDO6 YOU ROCK!!!
              Circle and polygon...AWESOME!
              contour editor...GREAT IDEA!!!
              Really amazing!
              THANKS!!!
              • B
                Ben Ritter
                Fredo6,
                As with all of you who pour so much of your time into these scripts, a big thank you for efforts and kindness to share.
                Look forward to working with this script.
                Ben
                • B
                  breezmisha
                  this is real cool!!! 😍
                    archimun
                    THANKS A LOT
                    • ely862meE
                      ely862me
                      Fredo,i was thinking if u have time to add an Arc on Surface tool that will really be awesome(all what u did is already awesome) !?
                      Thx!
                      Elisei
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                        remus
                        1. just type the number of sides followed by an 's', so itd look like this: 5 s
                        • JClementsJ
                          JClements
                          Fredo:
                          I can not draw on any surface using v1.2. They do seem to work on "white space" (no other geometry under the cursor).
                          I deleted all v1.2 files and reloaded v1.1 and v1.1 it works just fine. Your other scripts/tools also seem to work okay.
                          In looking over the documentation, I see you allow grouping and construction point creation...BRAVO (I wish SU had this built in for all their tools).
                          Perplexed.
                          Also:
                          1- the Line tool has a "generate as curves" option. What is that supposed to do, create a continuous/welded (non-segmented) polyline? I didn't see a definition of this in the PDF file.
                          2- How are the number of sides for the Polygon or Circle tool modified?
                          P.S. Have you noticed how some of Jim's toolbar icons work; if you double-click on them, an options menus appear where you can change parameters. The might be something to consider for your toolbar icons.
                          Regards, John
                          • fredo6F
                            Bizarre! Are you sure you do not draw over a Group? This would not work then, as it the tools on surface implies you draw over the active model opened.
                            The generate curve option is just for convenience, as it makes segments easier to manipulate. But, as you know, Sketchup would break the curves at some intersection of edges or faces. So, the Contour Editor does not use the Curve properties and instead reconstruct the topology of the contour based on looking for connecting edges, regardless how they were generated. This is why you can have in the same contours lines and polygons, or repair a polygon with lines on surface.
                            As Remus said, just type a number followed by an 's' (as in the native Sketchup Polygon / Circle tools by the way). You can enter the radius / diameter and the number of segments in the same command, separated by semi-column. This is described in the doc.
                            I am not sure, but I think this feature has dependencies on Windows. If I have time, I will try to address this general problem of options and values, most probably via a contextual Web Dialog box with the right click (so that you don't have to go across the all view to change things). Simply, I have found no way to use the right click without showing either the default contextual menu, or my own contextual menu when the right click happens to be on a selectable element.
                            Thanks to advise on your problem of drawing.
                            • JClementsJ
                              JClements
                              No, I am not drawing on a group. And when I am drawing on white space and right-click, some of the context menu items, such as "Done", do not work.
                              Also, I just now noticed that the Extra Parameters (or Tab key) of the BZ_Toolbar doesn't work. Would this indicate something in your shared scripts that has changed via v1.1 and v1.2 that is the problem?
                              Perhaps another script (I use a lot of them) is causing a conflict? Is there something that I can look for via the Ruby Console or could you add something to the Tools on Surface scripts that would report an error?
                              John
                              • fredo6F
                                John
                                Could you turn on the Ruby Console and check if anything is shown.
                                That could help. Thanks
                                • P
                                  pacha
                                  Hi all,
                                  I'm new to this usefull forum. This plugin seems to be very great, I'll download it and see.
                                  Thanks for your efforts
                                  • JClementsJ
                                    JClements
                                    Hi again, Fredo:
                                    Well, I tried the operating some of the tools with the Ruby Console open. I'm not sure what it reported will be of any help to you.
                                    As I mentioned before, the tools seem to work while drawing on white space (not on existing geometry). When doing so the Console reports nothing.
                                    When moving the mouse over geometry, the Ruby Console scrolls a series of information, extremely fast. If I read the display correctly, each tool repeats as series of 3 or 4 lines of code until the mouse is stopped. For example:
                                    1- Line Tool
                                    LineonSurface:139:in
                                    LineonSurface:518:in
                                    LineonSurface:899: . . . . . when the mouse is stopped, NOTE, there is NO "in" following the "899:"
                                    2- Circle on Surface
                                    LibonSurface:152:in
                                    LibonSurface:635:in
                                    LibonSurface:899:. . . . . when the mouse is paused, NOTE, there is NO "in" following the "899:"
                                    LibonSurface:418:in . . . when resuming to move the mouse
                                    LibonSurface:398:in
                                    LibonSurface:635:in
                                    John
                                    • fredo6F
                                      John,
                                      Could you give me more on the error (for instance on LineOnsurface), so that I can try to find out what's wrong with your set up.
                                      What bothers me however is that LineOnSurface has only 568 lines and you seem to get an error somewhere at line 899 !!!
                                      • ___olo_
                                        ___olo
                                        Thanks Fedro. it's very cool.
                                        Xin chào nhau giữa con đường
                                        Mùa xuân phía trước, miên trường phía sau
                                        • JClementsJ
                                          JClements
                                          Fredo:
                                          I apologize for not responding sooner to your request. I just got back from the SU bootcamp.
                                          I showed what was happening to Todd B. He indicated that it is probably a bug and that I need to show you a larger display of the Ruby Console when it is running and that it might give you a better indication of what is going on. So stay tuned.
                                          If all else fails, I could try removing other scripts one by one and then test ... but I've got a lot installed so it would take a while to do that.
                                          The only thing on my pc that has changed on my PC (I am running XP on my PC) within the last couple of weeks that I know of is that my IT people pushed an upgrade for IE6 to IE7. I can't see how that would cause this problem, however .. particulary since your first version on the line worked when reinstalled.
                                          • JClementsJ
                                            JClements
                                            Polygon on Surgace Tool:
                                            • 2 / 4
