    Ruby WebDialog that invokes a Java Calculator Applet
    10 Posts 5 Posters 1.0k Views 5 Watching
      todd burch
      I threw this together some time back. I snagged the Java calculator off the net and created the webdialog to wrap around it to do a quick proof of concept that a java applet could be used inside SketchUp. It works just fine on a Mac. I just tested it on Windows (SketchUp 6.0.515 with java 1.6.0_05 and Internet Explorer 6.0.2900.2180) and under SketchUp, the applet does not appear (just a grey window), but it does appear properly when Calculator.html is double-clicked under Explorer and it runs under IE natively... 😞 )
      The calculator applet could use some cleaning up, but otherwise, it's functional.
      I've packed it all up in a .zip file. If you want to see it work, dump everything (4 files) in your /Plugins folder.
      calcu.rb - the ruby webdialog script
      Calculator.html - the html window call by Ruby
      Calculator.class - the compiled java bytecode
      Calculator.java - the java source code in case you want to play around with it.
      Todd
      sketchup_ruby_java_calculator.zip
      • plot-parisP Offline
        plot-paris
        Hi Todd,
        apropos calculator:
        Is it possible to write a Ruby that enables you to do simple type in calculations?
        for example, I copy(move) an object and type in the distance (lets say 50), then hit enter. but if I want to move it only one third of the distance I just type in
        50 / 3
        and the object is moved one third of 50.
        the same could work when drawing geometry like a line.
        but I guess this is something the SketchUp guys themselve have to do because ruby doesnt give enough freedom to change every keyboard input, am I right? πŸ˜•
        • tbdT Offline
          tbd
          working on Windows with SU 6.4.112, Java 1.6.0_10 beta 13
          http://plugins.ro
            todd burch
            @plot-paris said:
            Hi Todd,
            apropos calculator:
            50 / 3
            I guess I don't understand. Like you said, you can type in 50 / 3 right now in the VCB and the object will move 16 2/3 units.
            A Ruby calculator is possible, but I guess I'm missing the use case.
              todd burch
              Good to know! Thanks TBD.
                plot-paris
                oh my god! didn't know this is possible!!!
                (tried it ages ago and it didn't work. dont know why)
                Todd, you made my day! 😍
                but why does it only work for / but not for *****, + or -? isn't that a bit inconsequent?
                  todd burch
                  You are right. Now, I see a use case for a MOVE tool with Calculator. This could be done. (Although I would rather Google modify the VCB to allow this!)
                  Todd
                  • tbdT Offline
                    tbd
                    see Move Tool help
                    think that / is more for creating copies at an equal distance apart than a calculator.
                    found out that we can move things to [x,y,z] - nice.
                    sorry Todd for the hijack.
                    http://plugins.ro
                      ScottPara
                      At the risk of sounding stupid, could you give us a screen shot of how this would work and what the application would be?
                      Scott
                      Love the fact that some HATE my avatar.....
                      • fredo6F Offline
                        50 / 3
                        The only problem with the VCB is that it does not work when you have decimalsin the numbers
                        For instance, if your unit is Centimeters and you type in the Line tool:
                        • "50.0/3" will give 3 cm
                        • "50.0/3.0" will give 50 cm
                        It's not very complex to supersede this in Ruby, but the trick is that you have to convert numbers to Float first. Otherwise, 50/3 will simply give 16, not 16.67. You can try in the Ruby console. So a straightforward #Eval() won't make it.
                        I had to do it in my script PlaneShear for entering angles (in degrees, radians or as a tangent value)
