    Pont du Gard
    57 Posts 15 Posters 10.9k Views 15 Watching
      Julius
      nice pics!
      i edited the arch: check it out and tell me what you think.
        pichuneke
        Much better πŸ˜„
        There is a lost single line at the bottom of the model, under an arc.
        Forgive my spanglish...
          Julius
          @pichuneke said:
          Much better πŸ˜„
          i know: the purpose of that line is to rotate correctly the model when i import the google earth terrain, and then to rotate it back when i want to edit it so that it's aligned with the axis.
            Julius
            @pichuneke said:
            Everything is fantastic!
            Forgive me, when I upload a render, what I want is that people tell me what mistakes I have done. I don't want congratulations and things like that, and I forgive to say it to the people.
            But is going to be one of the more visited models of 3D Warehouse. Congratulations πŸ˜„
            You must inform the owner of the group of UNESCO sites to add your model:
            Error 404 (Not Found)!!1
            (sketchup.google.com)
            It's one of the most interesting collections I have seen in 3D Warehouse.
            pichuneke, check out the UNESCO sites' collection! β˜€
              pichuneke
              Fantastic! πŸ˜„
              By the way Julius, you are from Italy. I am from Spain.
              What the... hell are we doing modelling in France? πŸ’š
                Julius
                @pichuneke said:
                Fantastic! πŸ˜„
                ehe... πŸ’š
                  pichuneke
                  How did you make the last one? It's impressive, I want to learn! πŸ˜„
                  • FrederikF Offline
                    Frederik
                    😲 😲 Those are AWESOME renders..!! πŸ‘
                    Cheers
                    Kim Frederik
                      This is GREAT Julius! πŸ‘
                        Julius
                        i'm glad you like them.
                        pichuneke, here's how i did the last one:
                        1- choose the photo where you want to 'put" your model
                        2- match the model with the photo with the photomatch function in SU. adjust the shadows so that they match as well as you can with those of the photo (to this purpose it would be better to have already placed the model in Goggle Earth. also it's helpful if you know the day and the time when the photo was taken. in my case, i got the photo from the web, so i had to proceed without this help.)
                        3- export the model to your render application. in this case i use Kerkythea. i used this export settings:
                        geometry: yes
                        lights: yes
                        clay model: no
                        photomatched: no
                        default UVs: no
                        4- render the scene corresponding to the matched photo with the default resolution (955x613)
                        5- when you're ready with the render, go back to SU. turn off the photo on the background. go to the scene with the matched photo.
                        turn off shadows and ope the "styles" window. among the "default styles" choose "02 HiddenLine". then edit the color of the edges (in HLS mode) and adjust the luminosty to about 97. then open the "Fog" window: uncheck "use background color" and turn the color from white to black simply setting the luminosity to 0. use the two slider to get the background to be black and the part of the model you want to put in the photo, white. eventually export a 2d graphic with the default resolution (955x613).
                        if you didn't understand this step, take a look at this video (just the first part, though also the second part may help):
                        [flash=425,355:3s79oftd]http://www.youtube.com/v/fDzNJYi6Bok[/flash:3s79oftd]
                        6- before going to PhotoShop, resize the photo: keeping the original ratio, adjust ONLY the height to 613.
                        7- open in PS the three images: the render, the "foggy model", the real photo.
                        http://img141.imageshack.us/img141/6016/pontdugard1qs0.th.jpg
                        http://img234.imageshack.us/img234/3576/pontfog2bp7.th.jpg
                        http://img299.imageshack.us/img299/1574/resizeofpontgardzz6.th.jpg
                        (notice the resoultion)
                        now select the render: in the "layers" palette double click the only layer existing ("Background") and a window will appear. make sure to have the default settings (name: layer 0; color: none; opacity: 100%) and click ok. select "add layer mask" at the bottom of the "layers" palette (third icon from the left). holding the "alt" key, click on the layer mask you've just created.
                        8- select the foggy image: go to "select -> all" then "edit -> copy" and eventually go back to the render "edit -> paste".
                        9- in the layers palette click on the colored image and you will see that the parts of the image corresponding to the black color in the layer mask are transparent. go to the "channels" palette and select the "layer 0 mask" channel. go to "select -> color range" and set fuzziness to 200. select the "RGB" channel and then using the move tool drag the selected part of the image to the real photo.
                        10- now select the clone stamp tool. select the "background" layer and (holding the alt key)
                        click in a certain point on the image. now go to "layer o", click in the same point and then, holding the mouse left button, drag the brush. for example if you have a tree in front of an house, you will have to drag the brush over that tree (which is hidden by the house. to this purpose it's helpful to adjust the opacity of "layer 0").
                        11- when you're done save the image both as a .psd (in case you will need to edit it) and as a .jpg.
                        hope you understand, even though it's likely i did many grammar mistakes πŸ’š
                          pichuneke
                          THANKS! 😍
                          I am going to save this page, to do it in the future. πŸ˜„
                            Julius,
                            This is a wonderful TUTORIAL! Thanks for sharing these steps! πŸ‘
                            (BTW did you know that you can even "clip render" your model in KT?)
                            Would you mind copying it (with the original image) into the Tutorial Forum?
                              Julius
                              no...how?
                                It's Fletch:
                                Video (Flash) - PDF - Forum post
                                πŸ˜‰
                                  Julius
                                  cool...though i think for the tutorial it's better the "depth mask" from SU because not everybody uses KT. (i will add it though)
                                    That's true. And thanks for the tut! πŸ‘
                                      Julius
                                      at last some renderings...
                                      pure kerkythea:
                                      http://img139.imageshack.us/img139/4325/pontdugard2wj9.th.jpg
                                      with an artistic photoshop filter:
                                      http://img167.imageshack.us/img167/8165/pontdugard2bqk9.th.jpg
                                      another pure kerky:
                                      http://img380.imageshack.us/img380/862/pontdugard3sw5.th.jpg
                                      http://img518.imageshack.us/img518/213/pontdugard4ge0.th.jpg
                                      KT + PS:
                                      http://img352.imageshack.us/img352/8489/pontdugardps1copiaff2.th.jpg
                                      This last one is my first attempt to put a model in a photo (see original photo)
                                        LowlyServant
                                        Hello Lucius,
                                        Great model with lots of detail!
                                        May I ask where you got the measurements of the aqueduct from? I have to make a 3D model of the pont du gard for a school project and while I can find some measurements online (like the height of the different tiers) I can't find all of them (like the height of the arch itself, or the position of the middle tier on the bottom tier). Also, the information I found is often inaccurate. It would be really helpful if you could tell me where you got the measurements from.
                                        Thank you in advance!
                                        • 3 / 3
