    [Plugin] 3d Shapes Tool (was: Pyramid Tool)
    53 Posts 21 Posters 52.3k Views 21 Watching
    • urgenU Offline
      urgen
      @macs said:
      I've done some more work on it, completed a cone tool
      and added a toolbar. I'm progressing with work, soon a new release
      with more 3d shapes.
      Well it's a sort of toolbar for newbies ๐Ÿ˜„
      who don't know how to draw more complex shapes in few steps.
      I'm sure expert modelist know well how draw these shapes,
      perhaps it will help when there are many to draw.
      ...Marcs, it is very good and useful idea! ๐Ÿ‘ I thought of it and wished to ask about it Chris ๐Ÿ˜• ... Success to you... It is necessary not only to beginners... really ! ๐Ÿ˜‰
      --pupil forever...------
        Macs,
        Before you invest much time in this project, have a look at shapes.rb (by @Last) downloadable from Didier's site here:
        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
        It will create an item in the Draw menu.
        I'm glad however that there are more and more ruby scripter around soo keep up the good work! ๐Ÿ‘
          Macs
          I've seen that script, mine is a little different, but it was useful to learn from it.
            OK then, I just wanted to let you know... ๐Ÿ˜‰
            • urgenU Offline
              urgen
              ////MMMMM ๐Ÿ˜’ ...... shapes rb.- table skript ๐Ÿ˜• ... SK-FIZ (shapes)-it only drawing tool, but it
              does not work with the keyboard... ๐Ÿ˜• Let's make that the keyboard there worked! It will
              be excellent and very useful tool! ๐Ÿ˜„ ๐ŸŽ‰
                CPhillips
                In case you haven't seen it. Here is a demo of the shapes that are in the Solids toolbar of SketchyPhysics. It should probably be split out as a separate plugin. But I have too many plugins as is.
                http://sketchyphysics2.googlecode.com/files/SketchySolids2.gif
                  Macs
                  Ok! This is almost identical at what i'm coding... ๐Ÿ˜†
                  I've missed this in SketchyPhysics.
                  I've seen there is some difference in how the shapes are drawn,
                  and I've inserted support for VCB input.
                  however here there is the new script, now "3D Shapes Tool"
                  3DShapesTool.zip
                    CPhillips
                    ๐Ÿ˜
                    Looks like you are doing great. But feel free to copy anything you want out of SketchySolids. It is also based on the rotated rectangle code.
                    • urgenU Offline
                      urgen
                      ...๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ don,t stop this work ,please! ๐Ÿ˜„
                      • JClementsJ Offline
                        JClements
                        Macs, nice work.
                        Is there any way to allow the tools to respond to a User Defined Axis?
                          Jim
                          Hi Macs,
                          Thank you for working on this. ๐Ÿ‘ It is a needed and important plugin, don't stop now!
                            CPhillips
                            Loving the plugin dude!
                            Suggestion. Once you place the shape it is hard to set the height. You need to have something to infer the height and if nothing is available it is frustrating. My solution was to add a construction line to the center of the shape after the second click.
                            http://sketchyphysics2.googlecode.com/files/3dShapesCLines.gif
                            Try adding the following line to the the ConeTool::increment_state() function.
                            def increment_state
                            	@moved = false
                            	@state += 1
                                case @state
                                when 1
                            		@ip1.copy! @ip
                            		Sketchup;;set_status_text "Click to set the radius"
                            		Sketchup;;set_status_text "Radius", SB_VCB_LABEL
                            		Sketchup;;set_status_text "Move mouse", SB_VCB_VALUE
                                when 2
                                    @ip1.clear
                                    Sketchup.active_model.entities.add_cline(@pts[0],@normal)
                                    Sketchup;;set_status_text "Click to set the height"
                                    Sketchup;;set_status_text "Height", SB_VCB_LABEL
                                when 3
                                    self.create_geometry
                            Getting rid of the cline and having it work right with undo is a bit tricky, but if you are interested I can walk you through it.
                              dylan
                              This is really nice macs and very useful.
                              Thanks ๐Ÿ‘
                              http://dmdarchitecture.co.uk/
                                Macs
                                [CUT]
                                Strange.. on my system my tool works differently ๐Ÿ˜ž
                                when you do the second click with the cone tool it goes up
                                and down with the height without being locked on the surface.
                                I have to review the code to see if I made some mistrake invocking
                                some method without "self.".
                                thank you for the suggestion on the costruction line, I'll think about it.
                                  CPhillips
                                  I figured this out. In my case I build a lot of shapes on a big floor plane. When I draw a cone it infers the height from the floor. I don't think this is a flaw in your plugin. But the construction line is still useful in many cases.
                                  • urgenU Offline
                                    urgen
                                    ....Please wait ....will be OK! ๐Ÿ˜‰ ๐Ÿ˜„ ..
                                      Macs
                                      You are right!
                                      I've adde the construction line feature ( ripped from your tool ๐Ÿ˜„ )
                                      It will be available in the next release, thank you.
                                      • urgenU Offline
                                        urgen
                                        Scripts is ready ๐Ÿ˜‰ , problems of translation(russian-english) ๐Ÿคฃ
                                        • urgenU Offline
                                          urgen
                                          ...This is both very interesting and useful topic ๐Ÿ‘ โ€ฆI wonder why the founders of SKETCH-UP havenโ€™t done the 3d shapes (primitives) earlier ๐Ÿ˜• โ€ฆIf we have raised such an issue and this caused that much interest, we have to finish it upโ€ฆ โ— I am not a script man, although many people say I would be capable of doing that quite a bitโ€ฆunfortunately, quite poor knowledge of English and the tough schedule do not let me study RUBY in more detailsโ€ฆI had a choice to make here: to draw or to writeโ€ฆI have chosen the 1st oneโ€ฆHowever, I do get the processes in scripts and can freely apply some changes for my personal convenience in my usage but not more than thatโ€ฆI quite like the style of painting the figures in SketchyPhysics ( Chris, I really appreciate it!) and the MACS style tooโ€ฆ I have selected the files responsible for SHAPES building (from SketchyPhysics) and have made a decision to turn for help to one amazing Russian man Sahi (you possibly remember his name from the script โ€œbuilding a houseโ€). In a few hours I got a response you can see belowโ€ฆ ๐Ÿ˜„ โ€ฆThis is a Russian version and not everything works ideally, but much respect for his talentโ€ฆhe does not know English, but still manages to write English RUBI (imagine yourself writing RUBI in Russian or Chinese, which you do not know!!)โ€ฆ ..The many people the many minds, but the last thing I want is him to be remoted from the forumโ€ฆ.thank you Sahi one more time! ๐Ÿ˜ .....all the parameters of the letters are ascribed with the help of the keyboardsโ€ฆvery convenient! ๐Ÿ‘ ...MACS, I think that would be useful for youโ€ฆAnd Chris---a comfortable supplementary for your SketchyPhysics. ๐Ÿ˜‰
                                          SketchyPhysicsShapes.zip
                                            CPhillips
                                            Thanks for doing that Urgen. But I recommend this only be used for reference. There is still a fair amount of physics stuff in there. And it that could conflict with future versions of SketchyPhysics.
                                            • 1 / 3
