    [Plugin] 3d Shapes Tool (was: Pyramid Tool)
    53 Posts 21 Posters 53.9k Views 21 Watching
      tomot
      Thanks Macs, I have been looking for a code snippit for finding 3d mid points
      and other points that work in all planes.
      thanks also for not hiding the code, ala encryption.
      my plugins
      tomot
        Macs
        Sorry for the title.. πŸ˜„ now it's correct.
        @tomot: it's nothing, this is just my first experiment.. I'm happy if it could be of some help to others programmers.
        • JClementsJ Offline
          JClements
          Good job and thanks!
            CPhillips
            @macs said:
            Hello,
            During my experiments with ruby programming for SU I've produced
            this tool for drawing pyramids based on rotated rectangle tool.
            Maybe it's useful to someone...
            usage:
            Menu->Draw->Rotated Pyramid
            I think it's easy to use, but suggestions are welcome.
            Nice job! I think modeling tools like this are sorely missing from the basic Sketchup functionality.
            Do you have any interest in expanding this to support other shapes? If so I would give you any support you need and I could provide a good head start on some of the other shapes (box, cylinder, cone, sphere, capsule).
              Macs
              I've done some more work on it, completed a cone tool
              and added a toolbar. I'm progressing with work, soon a new release
              with more 3d shapes.
              Well it's a sort of toolbar for newbies πŸ˜„
              who don't know how to draw more complex shapes in few steps.
              I'm sure expert modelist know well how draw these shapes,
              perhaps it will help when there are many to draw.
              • urgenU Offline
                urgen
                ...Marcs, it is very good and useful idea! πŸ‘ I thought of it and wished to ask about it Chris πŸ˜• ... Success to you... It is necessary not only to beginners... really ! πŸ˜‰
                --pupil forever...------
                  Macs,
                  Before you invest much time in this project, have a look at shapes.rb (by @Last) downloadable from Didier's site here:
                  http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
                  It will create an item in the Draw menu.
                  I'm glad however that there are more and more ruby scripter around soo keep up the good work! πŸ‘
                    Macs
                    I've seen that script, mine is a little different, but it was useful to learn from it.
                      OK then, I just wanted to let you know... πŸ˜‰
                      • urgenU Offline
                        urgen
                        ////MMMMM πŸ˜’ ...... shapes rb.- table skript πŸ˜• ... SK-FIZ (shapes)-it only drawing tool, but it
                        does not work with the keyboard... πŸ˜• Let's make that the keyboard there worked! It will
                        be excellent and very useful tool! πŸ˜„ πŸŽ‰
                          CPhillips
                          In case you haven't seen it. Here is a demo of the shapes that are in the Solids toolbar of SketchyPhysics. It should probably be split out as a separate plugin. But I have too many plugins as is.
                          http://sketchyphysics2.googlecode.com/files/SketchySolids2.gif
                            Macs
                            Ok! This is almost identical at what i'm coding... πŸ˜†
                            I've missed this in SketchyPhysics.
                            I've seen there is some difference in how the shapes are drawn,
                            and I've inserted support for VCB input.
                            however here there is the new script, now "3D Shapes Tool"
                            3DShapesTool.zip
                              CPhillips
                              Looks like you are doing great. But feel free to copy anything you want out of SketchySolids. It is also based on the rotated rectangle code.
                              • urgenU Offline
                                urgen
                                ...πŸ‘ πŸ‘ πŸ‘ don,t stop this work ,please! πŸ˜„
                                  JClements
                                  Macs, nice work.
                                  Is there any way to allow the tools to respond to a User Defined Axis?
                                    Jim
                                    Hi Macs,
                                    Thank you for working on this. πŸ‘ It is a needed and important plugin, don't stop now!
                                      CPhillips
                                      Loving the plugin dude!
                                      Suggestion. Once you place the shape it is hard to set the height. You need to have something to infer the height and if nothing is available it is frustrating. My solution was to add a construction line to the center of the shape after the second click.
                                      http://sketchyphysics2.googlecode.com/files/3dShapesCLines.gif
                                      Try adding the following line to the the ConeTool::increment_state() function.
                                      def increment_state
                                      	@moved = false
                                      	@state += 1
                                          case @state
                                          when 1
                                      		@ip1.copy! @ip
                                      		Sketchup;;set_status_text "Click to set the radius"
                                      		Sketchup;;set_status_text "Radius", SB_VCB_LABEL
                                      		Sketchup;;set_status_text "Move mouse", SB_VCB_VALUE
                                          when 2
                                              @ip1.clear
                                              Sketchup.active_model.entities.add_cline(@pts[0],@normal)
                                              Sketchup;;set_status_text "Click to set the height"
                                              Sketchup;;set_status_text "Height", SB_VCB_LABEL
                                          when 3
                                              self.create_geometry
                                      Getting rid of the cline and having it work right with undo is a bit tricky, but if you are interested I can walk you through it.
                                        dylan
                                        This is really nice macs and very useful.
                                        Thanks πŸ‘
                                        http://dmdarchitecture.co.uk/
                                          Macs
                                          [CUT]
                                          Strange.. on my system my tool works differently 😞
                                          when you do the second click with the cone tool it goes up
                                          and down with the height without being locked on the surface.
                                          I have to review the code to see if I made some mistrake invocking
                                          some method without "self.".
                                          thank you for the suggestion on the costruction line, I'll think about it.
                                            CPhillips
                                            I figured this out. In my case I build a lot of shapes on a big floor plane. When I draw a cone it infers the height from the floor. I don't think this is a flaw in your plugin. But the construction line is still useful in many cases.
                                            • 1 / 3
