    [Plugin] XRay Toolbar
    10 Posts 4 Posters 15.8k Views 4 Watching
    • daikuD Offline
      daiku
      Another simple little Ruby I wrote but use every day. This one is just a small 2-button toolbar that Toggles Xray and Toggles Perspective view. Icons could use some work, but here it is. Place all three files in your plugins directory. CB.
      XRAYToolbar.rb
      Clark Bremer
      http://www.northernlightstimberframing.com
      • W Offline
        watkins
        Dear Clark,
        Could you explain why you find this script useful? The X-ray view already exists as a button on a tool bar, and most people work in perspective view as a matter of course, so....
        Have I missed something?
        Kind regards,
        Bob
          remus
          I can imagine being able to turn xray on/off using a single button would be quite useful if you dont use any of the other view options (wireframe, shaded etc.) just so you can try and keep a bit of screen space available.
          • W Offline
            watkins
            Dear Remus,
            Sounds plausible, but I use the other views too and so I tend to have that tool-bar up and running. Just curious, that's all.
            Regards,
            Bob
            • daikuD Offline
              daiku
              Hi Bob. Maybe it's just specific to the type of work I do. I model complicated structures with mortise and tenon joinery (timber framing). So its very useful to be able to quickly turn xray on and off and peek inside the timbers to see the joinery without changing any other style settings. CB.
              Clark Bremer
              • W Offline
                watkins
                Dear Clark,
                I am always peaking inside things and so I might give it a go. I am already using your rot90 tool. Very useful! I like the way it rotates a component/group about a central axis rather than a corner. I also enjoyed playing with the script so that I could rotate any angle I liked, which brings me neatly to my next question. Do you think you could modify the script so that one could enter the rotation angle in a pop-up window. The default could be 90, which is your rotation of choice.
                Kind regards,
                Bob
                • daikuD Offline
                  daiku
                  Bob:
                  While this could certailny be done, I think it would take away from the utility of the thing: A single keystroke to rotate. I think others have already written the utility you're taliking about (mover.rb?), plus, the built-in roate tool lets you type the angle into the VCB. Someone has already sent me a modified version that supplies 3 commands to rotate 90 around any of the three axes. I've urged him to post it. CB.
                  Clark Bremer
                  • W Offline
                    watkins
                    Dear Clark,
                    You are probably right. Simple is often best.
                    Thanks for replying.
                    Regards,
                    Bob
                      Clark, this is a good idea for a script. I can see it being very useful when drawing joinery as you and I do. Since your plugin wasn't available when I first wanted a quick way to switch back and forth, I set a keyboard shortcut (I used Q) to toggle X-ray view on and off.
                      • daikuD Offline
                        daiku
                        You know, that's an even better solution. I actually developed this at the request of a student, but the shortcut key is the way to go. Sincere thanks for pointing out the obvious! CB.
                        Clark Bremer
