    Color
    4 Posts 2 Posters 996 Views 2 Watching
      subh
      Is it possible to put colors over a particular part of a component when the whole component color is by layer?
      If anyone have any solution PLEASE HELP ME.
      Subh
        spirp
        If I understand you correctly, you want a part of your component to have a color that differs from the rest of the component, when using "color by layer"? if so - yes, this is possible, just put the faces you want colored differently on a separate layer, with the color of your choice. Keep the component on the main layer, though.
        I've attached a skp with a cube, which is assigned to layer "1", while two of the faces are assigned to layer "2" and "3".
        Hope this helps,
        Olle
        ColorByLayerTest1.skp
          subh
          Thanks Spirp
          It is working.
          Many many thanks.
          Subh
            spirp
            Great!
            Good luck!
            // Olle
