    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 135.2k Views 85 Watching
      marcociacci
      @solo said:
      Look at first post on 1st page one of this thread.
      i click on [Plugin] SketchyBevel 0.1 but this is a link to another page!
      ...i'm going crazy. please HELP ME!!!
      • StinkieS Offline
        Stinkie
        Right-click (Windows) or press command and click (Mac), then download.
        • soloS Offline
          Stinkie you have been using your mac too long that you forgot the Windoze system.
          Left click and save in your SU plugins folder.
          • StinkieS Offline
            Stinkie
            lol! You're right. My humblest apologies! 💚 Also: CTRL + click, not command + click ...
            I'm gonna trade in my 8 cores for an abacus, I think.
              marcociacci
              i feel stupid! but i'm clicking on it ( [Plugin] SketchyBevel 0.1 )
              ...if there is another way to download it...SHOW ME PLEASE!
              • chippwaltersC Offline
                chippwalters
                Look at the very bottom of the first post-- under the animating demo. There's an attachment called:
                SketchyBevel.rb
                That's what you click on. If that doesn't work for you, then tell us what browser and OS you are using.
                Currently working with Cross-Reality technologies
                  marcociacci
                  THANK YOU!!!! THANK YOU!!! THANK YOU!!!
                  but before under the animating demo there wasn't this file, but the was a sentence on a yellow backgrond that i don't remember! maybe a stay a lot in front of the pc...
                  Howerer THANK YOU!!!
                    CPhillips
                    Like the built in Outliner tool Bevel doesnt work with "holes" in faces. You can usually work around those problems by subdividing the face with a hole.
                    Here is an example. The mesh on the left doesn't Bevel right. But add a line to break up the hole and it works. Then you can just erase the extra edges.
                    • StinkieS Offline
                      Stinkie
                      Thanks for the explanation, it clarifies a lot.
                      SketchyBevel.rb
                      Good call. Didn't realise he hadn't found the attachment.
                      • soloS Offline
                        Works like a charm, thanks for the work-around.
                        http://img150.imageshack.us/img150/9313/bevelgt0.jpg
                          kwistenbiebel
                          Thanks Chris,
                          Drawing that extra line indeed works 👍 .
                          • N Offline
                            NORTH_FROST
                            Thanks! This is great,good job ❗
                            http://www.northfrost.se
                              chippwalters
                              Yep, this tool is seriously cool. And when you combine it with Dale's Crease tool and Jim's soon to be released Jitter-- you can do some amazing things! BTW, Dales Crease tool should be a product unto itself, it's so useful, especially in parallel projection mode.
                              http://content.screencast.com/media/e851e27c-78ce-4280-ad41-a355f9537051_4b345325-c952-4893-b165-d46826e6afd8_static_0_0_BevelSubDJitter.gif
                                Daniel S
                                Thank you Chris!!! Extra line is the solution ☀ ☀
                                Daniel S
                                PS. Not very important but when you apply the sketchybevel tool 2 times.. the plugin create a lot of extra lines that are not used and not create faces... is there a way to easily eliminate this lines?
                                  CPhillips
                                  Daniel S
                                  Only thing you can do is turn off "cap holes" after 1st bevel and then fill them in by hand. Hopefully I can figure out how to eliminate the extra faces in future version.
                                  • W Offline
                                    witjazz
                                      remus
                                      Daniel, you could also try running that CAD cleanup script that was recently released (sorry i cant remeber exactly what its called or who its by 😛 )
                                      EDIT: this is the one i meant.
                                        dylan
                                        Missed this one while I was away, but a nice present upon my return - Thanks! 👍
                                        http://dmdarchitecture.co.uk/
                                          Daniel S
                                          Thank you, but it dosen´t work with this lines. I have another old script that removes unused Edges but don´t delete this ones.
                                          It´s not a big problem, but when you use soften edges this lines affect the model.
                                          Daniel S
                                          • david_hD Offline
                                            david_h
                                            😎 very cool! 😎
                                            Merci. Spasibo. Gracias. Danke. Tanks a lot!
                                            • 3 / 8
